Old 12-10-2006, 12:31 AM   #1 (permalink)
Hey here is the aks
arunks's Avatar
Default what is difference between vb and vb.net
I want to learn one of these.
guys tell me which should i practise and why..
also somebdy said me "there is very little difference in them..so learn VB first then just learn vb.net differences"
Plz suggest me what shud i do..
give genuine reasons and suggestions
yours truly
arun
The aks!!
have a nice day
arunks is offline
Old 12-10-2006, 01:07 AM   #2 (permalink)
String Phreak
mediator's Avatar
Default Re: what is difference between vb and vb.net
Hi, VB is old technology. So better learn VB.NET. Yea the difference is not much. I have only done VB and not VB.NET, but what I have heard is VB.NET is easier than VB. The difference between them is just like the difference between 98 and Xp i.e better libraries, user interfaces, boxes etc.
So in mah opinion u shud do VB.NET !
mediator is offline
Old 12-10-2006, 02:48 AM   #3 (permalink)
i have learned both VB and VB.NET... the main difference between them is that VB is a general programming language where as VB.NET is an Object Oriented Language... i think its better 2 learn VB.NET nw bcoz both look similar in syntax n environment.,,, so if u learn VB.NET u can easily learn VB on ur own....
RoughGuy is offline
Old 12-10-2006, 12:35 PM   #4 (permalink)
soham's Avatar
I think the difference is similar to the difference between C and C++ .
"Imagination is more important than knowledge. For knowledge is limited, whereas imagination embraces the entire world, stimulating progress, giving birth to evolution." ~ Albert Einstein
soham is offline
