11-10-2006, 11:59 PM
internaltv tunnercard or external tv tunner which is good in your opinion?
internal tv tunnercard or external tv tunner which is good? reply if u know?
12-10-2006, 12:30 AM
Laptoping
Re: internaltv tunnercard or external tv tunner which is good in your opinion?
Internal coz its better, cheaper and readily available.
External is always the last resort.
12-10-2006, 12:43 AM
if u dont wanna u to start yr pc for watcing tv, then buy external..
but in external u cant record anything..and they are costly then internal tv tuners..
depends upon u ..
Be like a postage stamp-stick to one thing until you get there.
12-10-2006, 12:50 AM
Laptoping
To do away with the confusion, External tvtuners are of two types - set-top box based and USB.
For more info, refer http://www.laptoplogic.com/resources...p?id=46&page=2
12-10-2006, 07:11 AM
Originally Posted by shashank4u
...but in external u cant record anything...
Is it that external TV Tuner Cards cannot record video?
P4 3.0GHz Dual-core.
Intel 945GNT MoBo.
1GB RAM.
Seagate 160GB SATA HDD.
HP 16X Dual Layer DVD Writer.
Coloursit 450Watt SMPS with NAVTECH cabinet.
Samsung SyncMaster 740N TFT LCD 17" monitor.
12-10-2006, 10:20 AM
yes , because it has no inside interface with the mobo and harddisk..
12-10-2006, 10:43 AM
Welcome To The Jungle
never knew that info.
Me n My Canon EOS 350D with EF 50mm f1.8
12-10-2006, 08:51 PM
Laptoping
External USB based tv-tuners card can record videos! No one even cares to check out the link.
15-10-2006, 12:26 AM
Dear,
If you have any chance to buy a notebook buy external so you can use in both systems, it is wrong thing that with external tv tuner card you cant record. I am recording with my external tv tuner card very smoothly, my tuner is not branded one , it is using empia chip
15-10-2006, 09:05 AM
go for internel n tht too pinnalce all tv card suxx.....
Im usin..this pinnacle card since 4 yrzz n workin..fine..
15-10-2006, 09:11 AM
yeah, i've seen many external tvtuner cards which aren't branded and can record, but,as conventional knowledege tells us, it is better to stick to the branded internal one if you want to good performace and after-sales support
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
15-10-2006, 09:29 AM
The Devil's Advocate
hmmm ..... iv heard external (usb) is better than the internal 1 coz it does not heat the inside and also u dont need to power on ur pc to c the tv which i feel is a + point
http://beingmanan.com
15-10-2006, 09:30 AM
GaurishSharma.com
also when buying a new one go for a card with a tv-out post so that u can connect ur tv directly with ur pc and watch vedios recored with the card
15-10-2006, 09:24 PM
thanks for the replies
15-10-2006, 09:29 PM
gooby pls
Internal TV Tuner Card is best !
15-10-2006, 10:10 PM
External cards give better quality because other components in the cabinet interfere with the signal in internal cards.
15-10-2006, 11:35 PM
Laptoping
It is the other way around. The external pinnacle 100e left me wanting for more. So if you have a desktop PC, it would be better off getting some internal ones unless ofcourse you plan to get a laptop in near future.
15-10-2006, 11:51 PM
Do we have any dual tv tuner cards available in India ?
(Single card with two engines). Its useful when using one channel to view and another for recording at same time. saves money and time.
Raj® Anyone else is not me...!!!
16-10-2006, 12:06 AM
#19 (permalink)
That depends on the particular model in question, but in general external tuners are free from a lot of interference that internal tuners are exposed to.
16-10-2006, 07:44 AM
#20 (permalink)
Internel is BEST dude...n Cheap Too
PInnacle Card...
Search this Thread |
