Old 11-10-2006, 07:38 PM   #1 (permalink)
Default Convert Color 32bit to 16bit
Anyone knows code to color 32bit color pixel value to 16bit value
rajesh_nk22 is offline
Old 11-10-2006, 07:41 PM   #2 (permalink)
gooby pls
Third Eye's Avatar
Default Re: Convert Color 32bit to 16bit
For what ?
Third Eye is offline
Old 11-10-2006, 07:45 PM   #3 (permalink)
jz2linkinpark's Avatar
right-click, properties, settings, color quality, High (32 bit)
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
jz2linkinpark is offline
Old 11-10-2006, 09:57 PM   #4 (permalink)
Wise Old Crow
blueshift's Avatar
Be specific when you ask questions here!
blueshift is offline
Old 12-10-2006, 01:13 AM   #5 (permalink)
aadipa's Avatar
32 bit colors are RGBA values each channel taking 8 bits
R - Red
G - Green
B - Blue
A - alpha
16 bit colors are RGB with 5 bits for each, or sometimes 6 bits for green, and 5 for Red and Blue each. More bits to green is because human eye can see more shades of green.
For converting a color from 32 to to 16 bit, each 8 bit color value must be scaled to proper 5 bit color value.
ie Red in 16-bit = Red in 32-bit * 2^5 / 2^8
ie Red in 16-bit = Red in 32-bit / 8
Hope this is what you wanted.
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 12-10-2006, 01:44 PM   #6 (permalink)
Sorry, for not posting question in details.
I have developed application in VB, which reads color values on screen using getpixel api, so whenever I use this api, I get different color values depending upon display properties set on my computer. If I change color quality from 32 bit(default where my application works) to 16 bit or 256 bit color value changes. To solve this problem, I want a function to convert 32bit color value to 16bit value.
Old 12-10-2006, 03:43 PM   #7 (permalink)
aadipa's Avatar
in that case my explanation should be enough to get you started.
aadipa is offline
