Old 11-10-2006, 03:13 PM   #1 (permalink)
hansraj's Avatar
Default sick of samsung
guys u all will laugh at my plight... i have 2 samsung drives, one DVD rom and another DVD writer. The ROM fails to close and finally closes after 10-12 attempts with me hitting on it with the available things around. So my writer decided to be unlike his brother(or may be sister) and it has started to remain closed even when i want the tray to be open.
so now i have two drives out of which one doesnt open and other keeps opening.
no virus intrusion .... already checked..
can anyone help me with this
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
hansraj is offline
Old 11-10-2006, 03:16 PM   #2 (permalink)
busyanuj's Avatar
Default Re: sick of samsung
before everyone recommends you to trash samsung and opt for some other manufacturers' drives, why not do a simple thing? take them to the service centre and get them fixed. that should do it.
busyanuj is offline
Old 11-10-2006, 03:16 PM   #3 (permalink)
Beneath The Eyelids
The Outsider's Avatar
those samsung ones are agressive pets, try to tame them, maybe you're lucky
The Outsider is offline
Old 11-10-2006, 03:22 PM   #4 (permalink)
hansraj's Avatar
i took it to the service center.. the one which keeps opening... the guy did something to it for about a week .. after 10 days the drive was in its old condition again... i took it again ... and the same thing happened... the prob is every visit he charges 150 and very soon i will end up money to buy a new ROM itself
hansraj is offline
Old 11-10-2006, 03:41 PM   #5 (permalink)
y filled with dust and dirt. find out a way of getting them cleaned. clean the lens even
prashanthnbhat is offline
Old 11-10-2006, 03:45 PM   #6 (permalink)
never go for samsung products unless and until it is a monitor
signature??? :???: Let Me Think About It!!!:-D
paul_007 is offline
Old 11-10-2006, 04:27 PM   #7 (permalink)
Come get Some
DukeNukem's Avatar
its a PJ
APNE COMP. KI KUNDALI KISI ACHE SE JYOTISHI KO DIKHAO, VASTU VISIT KARAO, FENG SUI KARAO, COMP. KI KAAL SARP PUJA KARAO
DUSARA TARIKA
SWAP THE DRIVES POSITIONS
DukeNukem is offline
Old 11-10-2006, 05:00 PM   #8 (permalink)
Kiran.dks's Avatar
Hehehe..very funny Hansraj. The problem is related to the improper motor action due to jammed gears and pulleys. Just clean them thoroughly but take care not to damage the lens. Lubricate the moving areas of slider and motor too. That should solve the problem.
Kiran Kumar R
Kiran.dks is offline
Old 11-10-2006, 05:10 PM   #9 (permalink)
18 Till I Die............
That's nothing new with Samsung drives and you aren't the first person to face it.
After a year of smooth operation, the Samsung drive will either have problems with the tray or with the lens.
So, be careful before buying Samsung products in the future.
Well I don't know if anything can be done of the current drives. I decide to dump my Samsung combo drive inside my drawer, where it is RIP, and buy a new DVD writer. No point in wasting any money over something like Samsung.
http://www.bash.org/?258908
mehulved is offline
Old 11-10-2006, 06:37 PM   #10 (permalink)
jz2linkinpark's Avatar
theres a small hole in the drive, shove a needle into it to force the tray to come out...after that restart the computer with the tray open, everything should work fine...
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
jz2linkinpark is offline
Old 11-10-2006, 06:49 PM   #11 (permalink)
Wise Old Crow
blueshift's Avatar
Thats exactly the similar condition at my side.
jz2linkin: i will try that.
blueshift is offline
Old 11-10-2006, 07:26 PM   #12 (permalink)
The Devil's Advocate
iMav's Avatar
samsung roms are born with this problem .... i too had the same problem with my drives .... and i started keeping an unfolded paper clip in side the drive till i got away with both of them for sony
http://beingmanan.com
iMav is offline
Old 11-10-2006, 10:19 PM   #13 (permalink)
kirtan's Avatar
I too am having some problems with these samsung drives.my dvd writer is very patient while writing cd's and dvd's.It takes all the time in the world to write the data.Swear that i will never again buy a samsung product.
Water can flow or it can crash.Be Water my friend.
kirtan is offline
Old 11-10-2006, 11:51 PM   #14 (permalink)
blademast3r's Avatar
If its within the warranty period then they will replace it jus as they did to my drive with same problem a few months ago..
blademast3r is offline
Old 12-10-2006, 03:29 AM   #15 (permalink)
Rebooting
Choto Cheeta's Avatar
Me too have a SamSung DVD ROM SD616E... which i bought when digit gave a DVD buying offer with Samsung to push its DVDs...
this drive is also very crepy with Tray... Ghostly Tray ... it has its own mind of opening and closing... some time non stop...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 12-10-2006, 09:05 AM   #16 (permalink)
executioner's Avatar
well i had also the same problem.my samsung drive would not close.if i pushed the button it would close for a few seconds and would come out.I used to tape my drive with a cellotape so that it would not open..u can try that or throw it out of u'r window cause it can't be fixed..That's what i did.
Successful is one who gets what he wants and Happy is one who is satisfied with what he gets.
executioner is offline
Old 12-10-2006, 09:34 AM   #17 (permalink)
shashank4u's Avatar
the samsung ROMS AND DVDROMS AND WRITERS are crap..never buy them.
many of my friends are facing the similar problems..
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 12-10-2006, 07:11 PM   #18 (permalink)
hansraj's Avatar
so the above 15 threads suggest that there is some serious design flaw with samsung... and the conclusion is DONT EVER GO FOR SAMSUNG DRIVE...even if it is free...
hansraj is offline
Old 12-10-2006, 08:42 PM   #19 (permalink)
well if it's then free take it and then sell it
Old 12-10-2006, 09:23 PM   #20 (permalink)
dIgItaL_BrAt's Avatar
welcome to the club!
dIgItaL_BrAt is offline
Old 13-10-2006, 10:34 AM   #21 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Hahaha . .. You've got company ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 13-10-2006, 10:56 AM   #22 (permalink)
Kiran.dks's Avatar
Hmmm....same problem faced by many people! How can Samsung mess up with their CD/DVD drives? Other than Monitors, I wonder which are the 'quality' products they offer?
Kiran Kumar R
Old 13-10-2006, 11:44 AM   #23 (permalink)
Pragadheesh's Avatar
Post Re: sick of samsung
dont spend even a penny more for ur samsung drive..it is of no use.. even i ave a Samsung drive & 'm facing the same problem.. i.e the tray cant be controlled by me.. it'll eject wen it wishes & it closes whwn it feels to do so..and understanding the wish & will of the drive i have to insert cds/dvds..
i gaveit twice for service & experienced d same problem.. for d 1st 2 weeks it'll function properly after then it goes outta control..
it irritated me to the core & finally i got a SONY drive.. now i care a damn about the samsung drive.. better buy some other drive..
SAMSUNG SUCKS
Pragadheesh is offline
