Old 10-10-2006, 11:50 AM   #1 (permalink)
Default screenshot
How to take screenshots of a movie playing in WMP11? I have tried a free software but it wouldnt work. is there any media player that has the buildin facility of screenshot?
tanmoy_rajguru2005 is offline
Old 10-10-2006, 12:56 PM   #2 (permalink)
Alive Again...
satyamy's Avatar
Default Re: screenshot
i use Windows Movie Maker for sreenshot
which come pre installed with WinXP
satyamy is offline
Old 10-10-2006, 04:05 PM   #3 (permalink)
SE><IE
Posts: n/a
If you take the screenshot by simply pressting PrtScr then the video will keep playing even in mspain. strange but yes.
goto option and move the hardware accelaration slider to leftmost i.e., disable hardware accelaration. Try it now , it will work.
Old 10-10-2006, 04:49 PM   #4 (permalink)
Tux Fan
shaunak's Avatar
On vista it works plain old printscreen works fine.
You can also use snipper.
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 10-10-2006, 05:10 PM   #5 (permalink)
Hanging, since 2004..
tarey_g's Avatar
As se><ie suggested or you can do this :
>Open Window Media Player
>Then go to Tools | Options
>In Options, select the Performance Tab
>Way below you click on the Advanced Button
>Uncheck “Use Overlays’
>Click Ok
now you can Use the standard ‘Print Screen Key’ Method OR u can press “CTRL+I”. This pops up a save as window after capturing the screenshot.
Windows 8 ? :lol:
I have a better OS installed, people call it Windows7 8-)
tarey_g is offline
Old 10-10-2006, 07:25 PM   #6 (permalink)
Cool Re: screenshot
didnt knew that ...thanks for the info
__________
>Click Ok
not working for me mate...
Last edited by NagpurDaMunda; 10-10-2006 at 07:25 PM. Reason: Automerged Doublepost
NagpurDaMunda is offline
Old 10-10-2006, 08:12 PM   #7 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
I think VLC Player has an option to take screenshots?
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 10-10-2006, 08:39 PM   #8 (permalink)
gooby pls
Third Eye's Avatar
Media Player Classic has an option to take screenshot.
Third Eye is offline
Old 10-10-2006, 11:29 PM   #9 (permalink)
7monk's Avatar
Power Dvd And Vcd Cutter Can Take Screenshoot..
7monk is offline
Old 11-10-2006, 04:16 PM   #10 (permalink)
pritish_kul2's Avatar
Intervideo WinDVD also can
pritish_kul2 is offline
Old 11-10-2006, 04:39 PM   #11 (permalink)
yaar simply use VLC media player.its t most acurate 1.
hi BHAILOG
apun ka subko salaaam-namaste
kuldeep bhardwaj is offline
