Old 09-10-2006, 12:42 PM   #1 (permalink)
saurav_nolakha's Avatar
Exclamation unable to name folder?
i am unable to name folder as "con" .I have tried it several times .
Plz help me to know the reason and a solution also..
saurav_nolakha is offline
Old 09-10-2006, 12:51 PM   #2 (permalink)
santu_29's Avatar
Default Re: unable to name folder?
u cant its a reseved name,,, there are a few more which cannot be used as folder names
Unless you have a dream, you are not going to achieve anything in life.
Shoot for the moon, even if you miss, youll fall in the stars.
******************ÏMPÕ§§ÏßL£ ϧ ÑÕTHÏÑG ******************
santu_29 is offline
Old 09-10-2006, 12:57 PM   #3 (permalink)
con is in short for CONsole. so its reserved word and hence cant use it to a folder
Raj® Anyone else is not me...!!!
rajas is offline
Old 09-10-2006, 01:08 PM   #4 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
solution: _con
Without sorrows happiness would be boring!
romeo_8693 is offline
Old 09-10-2006, 01:15 PM   #5 (permalink)
can u name others,plz?
Old 09-10-2006, 01:43 PM   #6 (permalink)
gooby pls
Third Eye's Avatar
Here are names that you won't give to a folder: CON, AUX, COM1, COM2, COM3, COM4, LPT1, LPT2, LPT3, PRN, NUL
Third Eye is offline
