Old 08-10-2006, 01:39 PM   #1 (permalink)
jz2linkinpark's Avatar
Default 'helpctr.exe' ctr not found
hey guys, now i clicked on the help and support button on control panel, and it said that 'helpctr.exe' not found, can someone tell me where i can get this file and where i have to place it, please?
thank you
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
jz2linkinpark is offline
Old 08-10-2006, 02:09 PM   #2 (permalink)
Wise Old Crow
blueshift's Avatar
Default Re: 'helpctr.exe' ctr not found
I found it in two locations:
C:\WINDOWS\ServicePackFiles\i386
C:\WINDOWS\PCHEALTH\HELPCTR\Binaries
I can send you the file if you want and ofcourse if its legal!
If the files are not present in those locations then there must be registry key corruption.
In your Reigstry Editor,
Goto HKLocalMachine\SOFTWARE\Microsoft\Windows\CurrentV ersion\App Paths\HELPCTR.EXE. Then create a new String value named Default. And assign the 'Value data' as "C:\WINDOWS\PCHealth\HelpCtr\Binaries\HelpCtr. exe" without double quotes. Change the system folder location correspondingly.
blueshift is offline
Old 08-10-2006, 02:12 PM   #3 (permalink)
oh well....
but come on man!
here, there are no original companies...think about it...think some more...open your email..attach the file...and send to XXXXXXXXXXXXXXXXXXX, thank you
but if its illegal in india..oh well
(\__/)
Old 08-10-2006, 02:20 PM   #4 (permalink)
Wise Old Crow
blueshift's Avatar
edited the post above ..
Old 08-10-2006, 02:24 PM   #5 (permalink)
thanks a million man..if you need anything from me..please don't hesitate to ask!
update: thanks anyway...at least can you tell me the size of the file?
(\__/)
Old 08-10-2006, 03:33 PM   #6 (permalink)
a_g = JPKN
s18000rpm's Avatar
why not try "System File Check"
To do this simply go to the Run box on the Start Menu and type in:
sfc /scannow
i think your PC MAYBE infected with a VIRUS, coz there's no way of this "helpctr.exe" Deletion.
i also had this similar problem, but with the "TaskManager" (taskman.exe),
i was not able to open TaskManager thru shortcut keys or thru its icon in sys folder.
i ran a Virus Scan in safe mode & then did the SFC, then my problem solved.
(AVG Free found 3 virus, i dont remember their name, it happened 7-8 months ago)
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 08-10-2006, 05:20 PM   #7 (permalink)
Distinguished Member
anandk's Avatar
check http://windowsxp.mvps.org/startmenuhelp.htm
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 08-10-2006, 10:35 PM   #8 (permalink)
Wise Old Crow
blueshift's Avatar
Originally Posted by jz2linkinpark
update:at least can you tell me the size of the file?
File size is 725 KB unzipped.
