Old 07-10-2006, 11:10 PM   #1 (permalink)
Default How to convert avi files into dvd format
I would like to know if there is any software to convert avi files into dvd format like .vob etc. Please help.
H.Lalnunmawia is offline
Old 07-10-2006, 11:53 PM   #2 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Cool Re: How to convert avi files into dvd format
AVI Files are generally those that get converted from VOB (DVD File Format)
When u reverse the conversion process,you will see a visible a loss of quality in video because AVI uses a MPEG2 Codec to get converted from VOB
May i know for what purpose you need this ?
techtronic is offline
Old 08-10-2006, 10:20 AM   #3 (permalink)
Default Re: How to convert avi files into dvd format
Thanks for the reply. I want to burn the best quality video file (such as captured by a video camera) into a dvd disk. I have adobe premiere cs and Nero 6 burning software.
Old 08-10-2006, 02:42 PM   #4 (permalink)
You can use ImToo MPEG encoder
There is a very fine line between genius and insanity. I have erased this line.
freezer is offline
