| Forum |
#1 (permalink) |
On closer examination I found that it had changed the default double click behaviour of the dive. By default the drive behaviour is supposed to be set to open (if you don't understand by what I mean, right click on any drive in 'my computer'....you'll see that 'Open' is highlighted. This is the default behaviour). Now for my external HDD drives, the default option had been changed to something called 'Auto', which actually turned out to be a link to the virus (C:\Windows\sxe.exe). My problem now is that, even though I've gotten rid of the virus, the menu hasnt changed in my computer. I can still access my drive if i choose right click->open. How do I change the default behaviour back to 'Open' and get rid of the 'Auto' option? Cheers Aditya
AMD 4400+ X2; Compaq Presario M2202TU; Dell Inspirion 500m; Windows Vista Ultimate |
#2 (permalink) |
Wise Old Crow
Goto Tools>Folder Options> FileTypes. Choose Drive and click Advanced. There you will see Actions:Auto, Open etc. If Open action is present then click it and choose Set Default. If it isn't then click New...
In the new Window that will come, under Action type Open and under 'Application used to perform action' type "C:\Windows\Explorer.exe /n" with double quotes. Save the action and set it as default. |
#3 (permalink) |
Well that really doesnt solve the problem. The default in Folder Options IS set to open, and all the drives on my comp open properly. Its only on my exteral HDD that the problem occurs....
any registry fixes?
#5 (permalink) |
@Vishal Gupta (MVP) can help solve your problem. Actually You need to modify some
settings in the Registry!!
* Imagination is more important than knowledge. -Albert Einstein |
#7 (permalink) | |
#9 (permalink) |
I just did. And all other subfolders under HKEY_CLASSES_ROOT\Drive but nothing relating to 'Auto' or even 'Open' for that matter. Only 'Find' is listed.
#11 (permalink) |
Only for drives. And that too only for my external HDD drives. Not the others.
#14 (permalink) |
It was acually sxs.exe, and has been found in four places
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\MountPoints2\{510314df-4dd3-11db-92be-806d6172696f}\Shell\Auto\command HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\MountPoints2\{510314e0-4dd3-11db-92be-806d6172696f}\Shell\Auto\command HKEY_USERS\S-1-5-21-796845957-842925246-839522115-1003\Software\Microsoft\Windows\CurrentVersion\Exp lorer\MountPoints2\{510314df-4dd3-11db-92be-806d6172696f}\Shell\Auto\command HKEY_USERS\S-1-5-21-796845957-842925246-839522115-1003\Software\Microsoft\Windows\CurrentVersion\Exp lorer\MountPoints2\{510314e0-4dd3-11db-92be-806d6172696f}\Shell\Auto\command Cheers, Aditya
#18 (permalink) |
Oh No! My probelms are back again!!!
Well removing it from the registry did do the trick, but everytime i reststart my comp its back to 'auto' again!!! HELP!!
#20 (permalink) |
Yeah. So I figured. But the virus scan (avast) does not detect it anymore. It had detected and removed it the first time....
| Bookmarks |
| Display Modes | |
