Old 07-10-2006, 10:02 AM   #1 (permalink)
ayush_chh's Avatar
Default via bluetooth
is it possible to connect two or more PCs via bluetooth??????
if yes, then how?
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 08-10-2006, 12:16 AM   #2 (permalink)
adit_sen's Avatar
Default Re: via bluetooth
yes. its possible. provided both the bluetooth adapters have Bluetooth LAN support, which most have anyway.
Just add each computer to the other's bluetooth list and pair them, just as you would do with a cell phone. Then use the Bluetooth LAN wizard in WinXP. Note: This wizard will show up in 'Network Connections' only if your adapter supports Bluetooth LAN
Cheers
Aditya
AMD 4400+ X2; Compaq Presario M2202TU; Dell Inspirion 500m; Windows Vista Ultimate
adit_sen is offline
Old 08-10-2006, 02:48 PM   #3 (permalink)
jz2linkinpark's Avatar
my friend did this once, with zoOM wireless bluetooth dongles...not as effective as normal WLAN though...
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
jz2linkinpark is offline
Old 11-10-2006, 01:38 AM   #4 (permalink)
the speed aint that good mate. If you intend to transfer big files, I'm afraid your gonna need a lot of patience. if you're just connecting the devices for small tasks, say printing, i suppose it shouldn't be a problem
desijays is offline
