As most(& mine) NOKIA support 4-Channel polyphonics & most Poly tones on NET are Standard 16-Channel MIDI file, i need few HTTP sites which have 4-Channel Polyphonic Tones. Should be a HTTP site.
Not WAP sites as I dont have WAP.
Thanks.
I suppose There Was a Software Called The Mobile Music Polyphonic....It Can Convert The Midi Files Into 4 Channel Tones......If I Remember Correctly i.e. .....Anyways U Can get It At http://www.topshareware.com/Mobile-M...nload-1712.htm
yeah, i khave that software. but the problem is that the converted 4 channel tones dont sound good. I need a WEBSITE that is dedicated(Has) 4 channel tones, not any software.
