Re: Java problem
Maybe he wants to install a higher version of Java (JRE 1.5). Tell me what's the error
message you are getting? I never faced such a problem!! Do one thing. Some program
is still using Java, so it's not allowing you to uninstall it!! Reboot the PC. First thing
you do is - 'Uninstall Java' from 'Add/Remove Programs' Also make sure that no startup
process is using Java!! In that case, disable that service (run 'msconfig' & disable it).
Reboot your PC, uninstall Java now.
* Imagination is more important than knowledge.
-Albert Einstein
