Old 05-10-2006, 11:01 PM   #1 (permalink)
pra_2006's Avatar
Question How to Convert NTFS to FAT32? Help
hi friends anyone can pls tell me how to convert NTFS to FAT32 in Windows XP pls reply me fast
pra_2006 is offline
Old 05-10-2006, 11:53 PM   #2 (permalink)
Super Hero - Super Powers
n2casey's Avatar
Smile Re: How to Convert NTFS to FAT32? Help
According to my knowledge, it is not possible to convert NTFS to FAT32. The only available option is FAT32 to NTFS conversion.
So format that partition to change from NTFS to FAT32.
Minds are like Parachutes :arrow: They work best when open
n2casey is offline
Old 06-10-2006, 12:01 AM   #3 (permalink)
sourav's Avatar
Default Re: How to Convert NTFS to FAT32? Help
wait a min. i remember that i read somewhere that it is possible without formatting. google it. remember it is not perfect, so back up
We must accept finite dissapointment. But we must never loose infinite hope.
sourav is offline
Old 06-10-2006, 05:11 AM   #4 (permalink)
please use partition magic 8
shemi4444 is offline
Old 06-10-2006, 09:15 AM   #5 (permalink)
plz. use partition manager like partbeta, partition maziq.
sonmani is offline
Old 06-10-2006, 09:34 AM   #6 (permalink)
mobilegeek's Avatar
Is it possible to do that .. i mean without loosing ur data ???
mobilegeek is offline
Old 06-10-2006, 10:29 AM   #7 (permalink)
Come get Some
DukeNukem's Avatar
Talking Re: How to Convert NTFS to FAT32? Help
AT FIRST ITS A PJ
YES its Possible to convert a NTFS partition into a FAT32 one
Here's How
1. First Backup All your Data to Some Other Place than the drive to be converted.
2. Then format the drive to be converted in fat32 as fat32.
3. restore the backup to this drive
Simple is'nt it (lol)
DukeNukem is offline
Old 06-10-2006, 11:26 AM   #8 (permalink)
gooby pls
Third Eye's Avatar
How many drivers that you have created.If you want to convert that drive where windows files installed,then it is not possible because you must format it.
Third Eye is offline
Old 06-10-2006, 12:41 PM   #9 (permalink)
virus_killer's Avatar
try this http://www.sysinternals.com/utilities
virus_killer is offline
