Old 04-10-2006, 12:00 AM   #1 (permalink)
Dipen01's Avatar
Cool - Burning DVD to another DVD !!
Hey there..
I hv this Original Video DVD...i want to make another copy of it..!!
So will just COPY DVD in nero work or ill have take any different steps to do that..!!
Thanx
I love walking in Rain ,because no-one knows i am Crying :|
Dipen01 is offline
Old 04-10-2006, 12:29 AM   #2 (permalink)
Super Hero - Super Powers
n2casey's Avatar
Default Re: - Burning DVD to another DVD !!
Simple solution is that, make a image of this on ur HDD using Nero and then burn this image file on a blank DVD.
Minds are like Parachutes :arrow: They work best when open
n2casey is offline
Old 04-10-2006, 01:58 AM   #3 (permalink)
nishant_nms's Avatar
u may need to use DVDdecrypter first
nishant_nms is offline
Old 04-10-2006, 07:30 AM   #4 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Yeah, copy DVD would work, unless its an original DVD which is region encoded.
kalpik is offline
Old 04-10-2006, 09:03 AM   #5 (permalink)
gooby pls
Third Eye's Avatar
First make it .iso in hard disk and then burn it on blank dvd.
The software required for making or burning: Alcohol 120%
Download Here: www.alcohol-soft.com/
Third Eye is offline
Old 04-10-2006, 02:40 PM   #6 (permalink)
Dipen01's Avatar
Oh then will hv to try couple of these things..
either way ill go with COPY DVD..first...
if nt then ..DVD decrypter..!!
btw..Alcohol wuldnt make any difference..its jst cloning soft....and even NERO IMAGE does the same work.....
Dipen01 is offline
Old 04-10-2006, 03:13 PM   #7 (permalink)
gooby pls
Third Eye's Avatar
First put dvd on dvd rom+writer and then run alcohol software,now make a .iso of inserted dvd(see alcohol,there is an image making option),it takes time so wait some minutes,then you have the iso of your inserted dvd,eject the inserted dvd then put blank dvd in your dvd-rom+writer.In alcohol software open the .iso and burn it(choose the image burning option to burn).
Old 04-10-2006, 05:03 PM   #8 (permalink)
Pragadheesh's Avatar
very simple... just make an image of the DVD using Nero , then burn it in the blank dvd..
Pragadheesh is offline
Old 05-10-2006, 04:34 PM   #9 (permalink)
Dipen01's Avatar
I knew all the above methods.. have been using Alcohol and Virtual CD..since ages...
its just i don wanna waste my DVD..so i ws js making sure..if Region Protection etc....problems doest arise...
Thanx a lot ..
will make an image thry NERO and wil burn on Blank DVD..if that doest work..
DVD Decrypter...
Dipen01 is offline
