Re: Can X-Ray Be scanned?
Actually, you can scan a x-ray without a transparency adapter. Transparency adapter is for slides! You can scan slides with these adapters and results will be similar to what it shows if they are put in a projector.
But for x-ray films, you don't need any adapter. Just scan them straight off with your scanner. At max, put a bright, spot-less, white paper at the back for the best light reflection.
