Old 02-10-2006, 10:41 PM   #1 (permalink)
The Devil's Advocate
iMav's Avatar
Default Live AV
guys is there any live antivirus software which i can put in my pendrive and need not install on the pc and where ever i plugin my pendrive i can scan the file and transfer it also making sure that no virus finds its way .... my college pcs are all infected ..... and they dont hav any anti virals
http://beingmanan.com
iMav is offline
Old 03-10-2006, 06:08 AM   #2 (permalink)
nil_3's Avatar
Default Re: Live AV
In Norton Anti-Virus 2004, I found that before installation, it checked the drives for virus. May be later versions also incorporated this facility.
P4 3.0GHz Dual-core.
Intel 945GNT MoBo.
1GB RAM.
Seagate 160GB SATA HDD.
HP 16X Dual Layer DVD Writer.
Coloursit 450Watt SMPS with NAVTECH cabinet.
Samsung SyncMaster 740N TFT LCD 17" monitor.
nil_3 is offline
Old 03-10-2006, 07:41 AM   #3 (permalink)
AJJU
azzu's Avatar
Default Re: Live AV
norton 06 also have same function
I love and Live to Design
azzu is offline
Old 03-10-2006, 07:54 AM   #4 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
Default Re: Live AV
http://nedwolf.com/Freeware-Portable-Security.htm
u can check this site.. it contains something of ur interest
Blogging @ http://classictutorials.com
the.kaushik is offline
Old 03-10-2006, 02:45 PM   #5 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: Live AV
Also try this:
ClamWin AV Portable
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 03-10-2006, 04:23 PM   #6 (permalink)
iMav's Avatar
Default Re: Live AV
^^ thanx vishal and kaushik
iMav is offline
