Old 02-10-2006, 01:49 PM   #1 (permalink)
nix
Senior Member
nix's Avatar
Default howto:introduce skips in songs
i need to remove the words like F*** and S*** in an mp3 file, how do i do it the professional way? all these days i used to cut that portion and it would sound really bad. but the skips in radio are good, only the vocals are removed...not the music. if not that good, atleast suggest something better than the cut operation.
thanks in advance,
nikhilspoliticalblog.wordpress.com- Common man bows to amitabh
nix is offline
Old 02-10-2006, 02:14 PM   #2 (permalink)
The Devil's Advocate
iMav's Avatar
Default Re: howto:introduce skips in songs
use soundforge and select the part u want to mute and fade it ...
http://beingmanan.com
iMav is offline
