Old 19-12-2004, 11:45 AM   #1 (permalink)
Default DOS troubles
i use win XP pro. i cant run any ms-dos files and i get this error. pls suggest a solution except reinstalling
deepakuma is offline
Old 19-12-2004, 01:25 PM   #2 (permalink)
veddotcom's Avatar
1. Insert the CD into the CD drive or DVD drive.
2. Click Start, and then click Run.
3. In the Open box, type cmd, and then click OK.
4. At the command prompt, type the following commands, pressing ENTER after each command:
expand CD-ROM Drive Letter:\i386\config.nt_ c:\windows\system32\config.nt
expand CD-ROM Drive Letter:\i386\autoexec.nt_ c:\windows\system32\autoexec.nt
expand CD-ROM Drive Letter:\i386\command.co_ c:\windows\system32\command.com
exit
5. Start or install the program. If the issue is resolved, do not complete the remaining steps. If the issue is not resolved, go to the next step.
6. Note: The Command.com file is not edited or created in this in the following process. Because of this, you may have to expand it from your Windows XP CD-ROM.
Start Notepad.
7. In Notepad, type the following entries: dos=high, umb
device=%SYSTEMROOT%\system32\himem.sys
files=40
8. On the File menu, click Save As.
9. In the File Name box, type Config.nt, and then click Save. Close the Config.nt file.
10. On the File menu, click New.
11. In the new blank document, type the following entries: @echo off
lh %SYSTEMROOT%\system32\mscdexnt.exe
lh %SYSTEMROOT%\system32\redir
lh %SYSTEMROOT%\system32\dosx
SET BLASTER=A220 I5 D1 P330 T3
12. On the File menu, click Save As.
13. In the File Name box, type Autoexec.nt, and then click Save. Close the Autoexec.nt file.
14. Start Windows Explorer. Locate the Config.nt file, right-click the Config.nt file, and then click Copy.
15. Right-click the %SYSTEMROOT%\System32 folder, and then click Paste.
16. Locate the Autoexec.nt file, right-click the Autoexec.nt file, and then click Copy.
17. Right-click the %SYSTEMROOT%\System32 folder, and then click Paste.
18. Locate the Command.com file, right-click the expanded Command.com file, and then click Copy.
19. Right-click the %SYSTEMROOT%\System32 folder, and then click Paste. Restart your computer.
For additional information, please refer to the Microsoft article in the "See Also:" section below.
Also Look this Website
http://support.microsoft.com/default...b;en-us;324767
veddotcom is offline
Old 19-12-2004, 04:44 PM   #3 (permalink)
thanx
Old 20-12-2004, 12:21 AM   #4 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Hmm.. You can also look here :
http://www.thinkdigit.com/forum/view...919&highlight=
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
