Go Ahead and Buy AMD Athlon 64 3700+ . You will need 939 socket motherboard.
Details for you
* AMD Athlon 64 3000+, 2.00GHz, 512KB L2, 754-pin.
* AMD Athlon 64 3200+, 2.20GHz, 512KB L2, 754-pin.
* AMD Athlon 64 3400+, 2.40GHz, 512KB L2, 754-pin.
* AMD Athlon 64 3400+, 2.20GHz, 512KB L2, 939-pin.
* AMD Athlon 64 3700+, 2.40GHz, 512KB L2, 939-pin.
* AMD Athlon 64 4000+, 2.60GHz, 512KB L2, 939-pin.
Amd Athlon 64 3700+ also available in socket 754 if you cannot get 939 socket CPU.
Best luck...Any of the Above Processor is a good buy .
