Old 18-12-2004, 08:20 PM   #1 (permalink)
mekalodu
iinfi's Avatar
Default Sony Erisson users
my friend has a Sony Ericsson K500i mobile
we r unable to transfer pics frm his mobile to his PC via IR
where can we get the software for the same?
the soft was not bundled with the phone!!!
the dealer also doesnt know abt the IR
mekalodu
iinfi is offline
Old 18-12-2004, 08:32 PM   #2 (permalink)
King of my own Castle
freshseasons's Avatar
Naaa one doest require anysoftware to exchange the files. just make sure you infrared is working.
Go to the connectivity options and click Infrared on .
Now Make sure infrared drivers on the PC are loaded and recognised .
Now place the pc and phone front to front.
Infrared is on top on K500i if you want to know.
The Pc should recognise the Phone and give something like " Click here to send the files to k500i nereby computer ".
Or right click the file and Click Send to infrared device.
No you are still not done. You now will see the messege that Pc ( or something ) is trying to send you file . Click yes to accept ?
Click yes and you are then done . Find the files under , Sounds , Pictures , Games Etc.
Type of files sonyEricsson k500i will accept is jpg,gif,mp3,jar,
Best Luck
freshseasons is offline
Old 19-12-2004, 12:08 AM   #3 (permalink)
I`m not sure abt this ... :roll:
I have a T610 when i tried to transfer pics at first the same thing happened .
just change the name without any spaces or symbols ..
Me - Gone :(
sr_ultimate is offline
Old 19-12-2004, 01:04 AM   #4 (permalink)
mekalodu
iinfi's Avatar
Default files get transferred from PC to Mobile but not vice-cersa
files get transferred from PC to Mobile but not vice-cersa....
another friend says that a software for the mobile from the mobile manufaturer is required ....
but the mobile manufaturer has not given him any software ...
transferring files from the PC to mobile in any case does not require any software ....
files from Mobile to PC does require one...
mekalodu
iinfi is offline
Old 19-12-2004, 11:09 AM   #5 (permalink)
gxsaurav
Posts: n/a
you don't need any software to transfer files from the fone to computer, the SE File manager is not required at all I tried it, useless & slow.
Simply plug the IR adapter in the USB port, then wait for the device found dialog, then install drivers
Check if the infrared service is on in services.msc, if off then turn it on
now turn on IR in you cell, & place it near the IR adapter connected to PC, your PC will detect & ask for drivers for K500i series modem, ignore it or use windows update ot find them
then right click on the IR icon in the system tray & configure it to accept files from other computers, & specify a folder, by default it's desktop
After that click on a file in your fone, select Send via inreared, & place it near the adapter
I use the same trick with my K500i
IR is not supported by SE File manager for T610
Old 19-12-2004, 04:15 PM   #6 (permalink)
goto Infrared Settings and Set the Option
'allow others to send files to your computer using infrared'
and 'Notify me when receiving files'
Thats should do it.. (Works wid my T610)
\"Hating people is like burning down your own house to get rid of a rat\" - Harry Emerson Fosdick
\"A Pessimist is one who makes difficulties of his oppertunities; an optimist is one who makes oppertunities of his difficulties\" - Reginald B. Mansell
oh yeah.. my Fav Quote
\"Sometimes a winner is just a dreamer who never gave up.\"
allajunaki is offline
Old 19-12-2004, 11:44 PM   #7 (permalink)
mekalodu
iinfi's Avatar
Default We did all this b4
We did all this b4
but any ways we ll try it again
thanks for all ur replies
mekalodu
iinfi is offline
Old 21-12-2004, 04:02 PM   #8 (permalink)
HAF 922 Owner
i_am_crack's Avatar
i have t630.... i have bluetooth to do the job but only from system to mobile i can transfer the data..
Well Actually I forgot to say Hi to you???? Can I say now???
i_am_crack is offline
Old 27-01-2005, 06:44 PM   #9 (permalink)
Default Where is USB Port in K500i ?
On most of the webites, in the reviwe of K500i it is written there that it has a USB Port.
Can any body here tell me where is USB port in K500i ?
If anyone can provide the photo, i will be really thankfull.
I also want to know what is the transfer speed of Irda from PC to mobile in respect of MB/ min, coz yesterday i transfered a 2.4 Mb mp3 file and it took about 6-7 minutes in that process.
Is that speed ok or is there any problem in my USB-Irda or Handset.
Kapil Wadhwa
hikapil@yahoo.com
http://www.flashwires.com
hikapil is offline
Old 28-01-2005, 09:42 AM   #10 (permalink)
Well.. I had that prob initially.. Try this one anyway.. Put ur Phone Manager software on startup.. You should have the phone manager software icon on your SysTray before u can transfer stuff from Mobile to PC..
Try this and let me know.. In my case, it worked.. (wid my 3660)..
SmoothCriminal is offline
Old 28-01-2005, 12:05 PM   #11 (permalink)
aadipa's Avatar
For file transfer no extra software is needed
btw if u are having SE phone do geta copy of FMA [ http://fma.sourceforge.net/index2.htm ].....
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 28-01-2005, 12:09 PM   #12 (permalink)
mekalodu
iinfi's Avatar
Default does SE provide phone manager software??
SE does not provide phone manager software along with the phone
what to do in that case?
mekalodu
iinfi is offline
Old 28-01-2005, 01:02 PM   #13 (permalink)
gxsaurav
Posts: n/a
U have to download it from their website, but it is quite useless, really U don't need it, if U want I will write U a compleate guide to setup K500i connection to PC to send files here
Old 28-01-2005, 06:16 PM   #14 (permalink)
mekalodu
iinfi's Avatar
Default gr8 man thanks
gr8 man plz ... if u dont mind ...
Thanks
mekalodu
iinfi is offline
Old 29-01-2005, 10:23 AM   #15 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
if nuthin works.. buy a usb data cable (imitations starts @ 900/-.. original @ 3000/-), stick it into the phone... USB port is under the phone..near the QUICKSHARE symbol; on it's bottom (pardon the pun)
Then try the cd provided with the cable.. install sw, after installation..in My Phones folder (on the desktop), search 4 K500i phone... if located.. go into this & voila.. there r ur files. U CAN UPLOAD OR DOWNLOAD THESE FILES IN & OUT OF THE PHONE
But the usb cable i got 900/-wala was damn slow.. most probably it was usb 1.0... so...
koolbluez is offline
