Old 18-12-2004, 05:31 PM   #1 (permalink)
Default NAV Live Update Prob.
I recently downloaded Latest live update version but when i try 2 connect 2 downloaad virus def. it shows an error LU1814: Live Update couldn't retrieve update list plz. help...
prabhatmohit is offline
Old 18-12-2004, 05:43 PM   #2 (permalink)
alib_i's Avatar
im getting that error too ..
i think the LiveUpdate servers are down .. or may be too busy
alibi
-Metallica
alib_i is offline
Old 18-12-2004, 07:52 PM   #3 (permalink)
from symantec itself
http://service1.symantec.com/SUPPORT...02082616293813
a simple google .. and the first result
ofcourse not necesary that this applies
give it a shot
No Mercy, No Limits.
theraven is offline
Old 18-12-2004, 10:05 PM   #4 (permalink)
alib_i's Avatar
for me it was just some busy LU server ..
i got connected later ..
you can check the link out @prabhat
alibi
-Metallica
alib_i is offline
Old 19-12-2004, 11:54 AM   #5 (permalink)
Default same
I downloaded the Live update file from
as suggested by theraven ,using Flashget. But I can't open that file, it asks 4 the prgram from which I want 2 open it.
Old 19-12-2004, 12:19 PM   #6 (permalink)
Ethan_Hunt's Avatar
Well Here's The Link To Download ur Desired Updates Directly.....Its The Norton Intelligent Updater......Just Dowload The Highest MB exe File From The Link and just run it 8)
http://securityresponse.symantec.com.../US-NAVCE.html
Ethan_Hunt is offline
Old 19-12-2004, 02:44 PM   #7 (permalink)
Default same
Forget Every Other Links and Check This one out and Download ur Update......
Just Tell Me If It works
Well as far as these files r concerned they r of greater size as compared 2 lie update files nt it not possible 4 me 2 download these big files every 3/4 days on my dial-up..
Old 20-12-2004, 12:37 AM   #8 (permalink)
Default Re: same
Open using NAV ! Thts wht u wanna update right ?
or try opening with NAV Updater an exe file !!
Hopetht works !
Vande Mataram - Two words that became a Fiery War Cry and Electrified the nation towards Freedom. A mantra that instills a sense of Pride and belonging.
go4inet is offline
