27-09-2006, 01:00 PM
HELP AND SUPPORT
WMP 10 error
I am not able to open windows media player 10.. I am gtting the msg "An internal application error has occured"..Now is there a way i can rollback to 9 or solve this problem
Some1 see this and help me out guys
27-09-2006, 01:49 PM
Re: WMP 10 error
If you have the setup file, try running it again. It will install and hopefully repair it. Else you can try installing wmp 11 beta.
27-09-2006, 03:00 PM
gooby pls
Re: WMP 10 error
Reinstall the WM10.
27-09-2006, 04:23 PM
Re: WMP 10 error
I have posted a PM. See that for instructions to solve your problem.
27-09-2006, 05:08 PM
HELP AND SUPPORT
Re: WMP 10 error
Dont suggest me to use wmp11..I am happy with 10...Reinstalled it and didnt work...any method to uninstall wmp10....I cant find it in ADD/Remove programs  . Did an AV scan as JGURU said but didnt help.
27-09-2006, 08:42 PM
Re: WMP 10 error
have u checked the box "show updates" (top right corner ) of add/remove window .
to solve this problem simply reinstall it .
28-09-2006, 12:26 PM
Distinguished Member
or from 'add remove windows components'.
soln here : http://www.opentechsupport.net/forum...c/27451-1.html
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
28-09-2006, 01:13 PM
HELP AND SUPPORT
Re: WMP 10 error
Originally Posted by anandk
I have uninstalled wmp10 and i wasnt able to boot in to my comp after a restart so now i am in safe mode so how do i follow the steps  ..>And i cannot open wmp 9 also..It doesnt open and i dnt get any error ..I am getting this error when i am trying to reinstall wmp10
[img=http://img82.imageshack.us/img82/2374/1bu1.th.jpg]
28-09-2006, 02:02 PM
Re: WMP 10 error
From where to download wmp 11?
28-09-2006, 03:44 PM
HELP AND SUPPORT
Re: WMP 10 error
This is only the beta version and dwnld it frm here
28-09-2006, 08:47 PM
Re: WMP 10 error
y dont u uninstall ur wmp 10/9 ?
run a registry cleaner (ace utilities is my favorite, else ccleaner is good enuff)
reboot.
and then do a fresh install of wmp10.
shud take care of ur probs, uh ?
work in safe mode if reqd.
hope u always create a systemrestore point b each trobleshooting steps
addl info here too http://support.microsoft.com/?kbid=831430
Microsoft® MVP
28-09-2006, 10:07 PM
HELP AND SUPPORT
Re: WMP 10 error
reboot.
Ran some 3 good registry cleaners like registry mechanic,ccleaner,Tune up utilities...I have unistalled wmp10...But when i try to reinstall it..i get that error which i have shown in my previous post..I am still in Safe Mode now and i am not able to boot into windows..Is a frresh reinstall of xp the only solution  ...See the link below for the error
http://img82.imageshack.us/my.php?image=1bu1.jpg
__________
Did a system restore and followed the 1st method in the link below and problem solved
__________
I would like to quote this solution for people who may find this as a problem in future
An internal application error has occurred.
CAUSE
This issue may occur if one or more of the Jscript registry key settings are incorrect. This behavior may also occur if the Jscript.dll file is missing or damaged.
RESOLUTION
To resolve this issue, use the following methods in the order that they are presented.
Method 1: Reregister Jscript.dll and Vbscript.dll
1. Click Start, and then click Run.
2. In the Open box, type regsvr32 jscript.dll, and then click OK.
3. Click OK.
4. Click Start, and then click Run.
5. In the Open box, type regsvr32 vbscript.dll, and then click OK.
6. Click OK.
If either of the files do not register as expected, or if you receive an error message, the system file may be missing or damaged. To extract the missing file in Microsoft Windows XP, follow these steps:
2. In the Open box, type msconfig, and then click OK.
3. Click Expand File.
4. In the File to restore box, type the name of the file that you want to restore.
5. In the Restore from box, type the path of the Windows XP .cab file where you want to restore the file, or click Browse From to locate the Windows XP .cab file.
Note The Windows XP .cab files are stored in the I386 folder on the Windows XP CD.
6. In the Save file in box, type the path where you want to extract the new file, or click Browse To to locate the folder that you want.
7. Click Expand.
8. In the System Configuration Utility dialog box, click OK. If you are prompted to restart the computer, click Restart.
Open a dialog box that previously experienced the issue that is described in the "Symptoms" section of this article. If the issue recurs, go to the next method.
Method 2: Edit the registry
Warning If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk.
2. In the Open box, type regedit, and then click OK.
3. Locate the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\CLASSES\CLSID\{f414c26 0-6ac0-11cf-b6d1-00aa00bbbb558}\In procServer32
The (Default) value data should contain the following value:
C:\WINDOWS\SYSTEM\JSCRIPT.DLL
If it does not, double-click Default, type C:\WINDOWS\SYSTEM\JSCRIPT.DLL in the Value data box, and then click OK.
4. The ThreadingModel value data should contain the following value:
Both
If it does not, double-click ThreadingModel, and then type Both in the Value data box.
5. Locate the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\CLASSES\CLSID\{f414c26 1-6ac0-11cf-b6d1-00aa00bbbb558}\In procServer32
6. Repeat steps 3 and 4 to edit this key, and then go to step 7.
7. Locate the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\CLASSES\CLSID\{f414c26 2-6ac0-11cf-b6d1-00aa00bbbb558}\In procServer32
8. Repeat steps 3 and 4 to edit this key, and then go to step 9.
9. Exit Registry Editor.
Reason: Automerged Doublepost
28-09-2006, 10:30 PM
Re: WMP 10 error
glad the opentechsupport link helped u
Microsoft® MVP
08-10-2006, 04:55 PM
Re: WMP 10 error
I have the same error last few days & read this thread but cannot solve the problem.
Method 1 did not solve the issue for me so that is not the problem in my case.
Method 2
I searched for the folowing reg keys but they are not there.
So what could be the reason?
Search this Thread |
