Old 27-09-2006, 11:48 AM   #1 (permalink)
pritish_kul2's Avatar
Default Registry Cleaner
Can anybody guide me about registry cleaner's because my spiderman is not working and someone suggested a registry cleaner
__________
so no one knows about registry's here?
Last edited by pritish_kul2; 27-09-2006 at 11:48 AM. Reason: Automerged Doublepost
pritish_kul2 is offline
Old 27-09-2006, 11:54 AM   #2 (permalink)
Welcome To The Jungle
sysfilez's Avatar
Default Re: Registry Cleaner
download the s/w called registry cleaner. its good.
Me n My Canon EOS 350D with EF 50mm f1.8
sysfilez is offline
Old 27-09-2006, 02:27 PM   #3 (permalink)
Distinguished Member
anandk's Avatar
a registry cleaner wont make ur game run ok again. u shud reinstall it again.
btw ccleaner is a good freeware registry, etc cleaner www.ccleaner.com
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 27-09-2006, 08:47 PM   #4 (permalink)
clmlbx's Avatar
u can use REGISTRY MECHANIC . THIS WILL REPAIR YOUR REGISTRY .
clmlbx is online now
Old 28-09-2006, 12:16 AM   #5 (permalink)
The Sexy Beast
Registry mechanic is the best.but ccleaner is very close to it also it is free.but it does not defragment registry.
ratedrsuperstar is online now
Old 28-09-2006, 09:51 AM   #6 (permalink)
Unhappy Re: Registry Cleaner
i asked activison about this it said-
You need to delete the registry keys for the game.
1) Click on the Start button > Run and type regedit.
2) Click Registry > Export Registry File.
3) Save it to a place that you will remember. (We are exporting the registry in case something happens to the registry you always have a backup to use).
4) Then go to HKEY_LOCAL_MACHINE\Software\Activision\Spiderman
5) Delete the folder Spiderman
but, when i type regedit in the run it says that another program using it?
I found out the regedit file. now it's working
Old 28-09-2006, 11:40 AM   #7 (permalink)
deathvirus_me's Avatar
CCleaner to clean the registry
TuneUp to clean / defragment the registry
deathvirus_me is offline
Old 28-09-2006, 11:22 PM   #8 (permalink)
nishant_nms's Avatar
TweakNow RegCleaner
nishant_nms is offline
Old 01-10-2006, 03:46 PM   #9 (permalink)
Tux Fan
shaunak's Avatar
I recomend ccleaner.
you can also try spybots internals check found in the tools menu.
@pritish_kul2: it may be possible to clean out one problem but for the several hundreds you need a cleaner.
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 02-10-2006, 05:21 PM   #10 (permalink)
tweak now regclener professional..........best one i have seen
mkmkmk is offline
Old 02-10-2006, 06:02 PM   #11 (permalink)
Pragadheesh's Avatar
Post Re: Registry Cleaner
frenz , wats the use of cleaning the registry. i heard that cleaning the registry without knowing bout it causes lots of problems..
Actually why do u need to clean the registry??
Pragadheesh is offline
- by Krow
