Old 26-09-2006, 04:22 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Website help ! ! !
i have a menu table where links in seperate rows r present 4 navigation ....... bgcolor is blue .....
now i want is, when i have mouseover state bgcolor of invidual row should change 2 white ......
how can i do that ???
with css, is it possible ??? help plz
ax3 is offline
Old 26-09-2006, 04:59 PM   #2 (permalink)
Default Re: Website help ! ! !
save in stylesheet.css:-
tr:hover { background-color : #ffffff };
Include in your webpage head:-
 <link rel='stylesheet' type='text/css' href='stylesheet.css' />
Freakish Attitude :cool:
freakitude is offline
Old 27-09-2006, 01:35 PM   #3 (permalink)
ax3
ax3's Avatar
thanx 4 reply .......
if css in same pg then where 2 put the code .........
ax3 is offline
Old 27-09-2006, 01:41 PM   #4 (permalink)
Anand_RF's Avatar
Put it below one of the lines having css code in that page.
Anand_RF is offline
Old 05-10-2006, 07:05 PM   #5 (permalink)
tuxfan's Avatar
tr:hover won't work in IE and unfortunately, IE is still the most used browser!!
What you can use is display: block;
Have a look at http://www.deitydarshan.com (don't blame me for the looks or frames ). Have a look at the button on the top-right corner. Its done with CSS. If the border is made 0 and the buttons are stacked one over the other rather than next to each other, it will give you the desired effect.
tuxfan is offline
- by Krow
