Hmm Trouble Trouble Trouble!!
Primary Master
M
Ptimary Slave
S
Secondary Master:2P
Secondary Slave :2S
Attached 7200 RPM 80 GB HDD as PM and 5400 RPM HDD as PS.
Bios showed :
IDE PM -> 7200 RPM HDD
IDE PS -> NOne !!!
Exchanged the disk's posn, then
Bios Showed :
IDE PM ->7200 RPM HDD
IDE PS -> NOne !!
I thought maybe this is happening due to IDE Cable problem.
SO exchanged the cables of Primary IDE and Secondary IDE .
Same Problem!!
Then connected,
PM-> DVD ROM
PS-> 7200 RPM HDD
2M-> 5400 RPM HDD
2S->CD writer
Bios Showed:
IDE PM->7200 RPM HDD
IDE PS->DVD ROM
IDE 2M->5400 RPM HDD
IDE 2S->CD Writer
Felt Like Busting that blloooddddy BIOS!!
Went online and Checked the term "Connect" +"two" OR "2" +"Hard" +"Disk" OR "Drive" in Google.
A page from Driverguide.com had the step by step guide.
Read it, pretty much did the same earlier, only neglected the term "Jumper Setting" [also mentioned in the forum by Tuxfan, amit_w and grinning_devil ] earlier. I had the term confused with the IDE Cable jack!! The drawing showed me what that damned piece of 2 pin connector was!!!
Went back and checked the JUMPER SETTING of both HDDS.
40 GB seagate 5400 RPM had "One Drive supported" enabled, so this was causing the problem. :roll:
But 80 GB 7200 RPM had "Cable Select" enabled .
With some trying changed the J Setting to :
40 GB -> Slave
80 Gb -> Master,
Connected 80 GB as PM
Connected 40 GB as PS
Bios detectd every thing F I N E !
Now I SHUD BE HAPPY, NO ?
HA HA HA HA, Not so lucky!!
This many times of Juggling has caused the primary active partition of 40 GB HDD [which had Win XP] to become corrupt!! Bloody HELL
Now How do I Boot?
USED FDISK, DELETED PARTITIONS , CREATED SOME, INSTALLED NEW OS!!!, .....
The day Concludes and I'm exhausted :roll:
The next part of this boring story will not come up unless I manage to get Norton Ghost 2003 to image my primary partition [ Even it is throwing up error 36000 !!!]
THX TO ALL 4 Helping me.
May The TECH LORD be with u!!
