Originally Posted by thilina
I am in sri lanka,so cant get your Brodaband conn.
I need a Static IP address coz I wanna remotely control My pc & specially download manager
So if its a dial-up, someone will start the connection before you can remotely control. Right? Then that person can find out the IP and tell you right there in a minute!
Or do you intend to keep it connected continuously? In that case, your IP won't change unless you re-connect!
