Old 23-09-2006, 07:56 PM   #1 (permalink)
Default archive
I hav a 3.2GB folder and my sys doesn't hav a dvd burner. Now i want to transfer this to another sys. but i cannot remove this hard drive. So my only way out is to split them into archive of size which would fit in a cd and then move them to the other system..
Which file archiver would do this job best.. I hav tried 7z and Zipgenius 6.0 both of which doesn't do things the proper way it should have been done specially when files or folders are in excess of 1 GB. What other file archiver and splitter would you suggest..
And mind tht the format of the archive has to be supported by the Nero Application when writing to the cd and when inflating the archive contents in the other sys.
hariharan is offline
Old 23-09-2006, 08:16 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: archive
The BEST will be use WinRAR
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 23-09-2006, 08:28 PM   #3 (permalink)
Default Re: archive
yes use winrar
sanju is offline
Old 23-09-2006, 09:46 PM   #4 (permalink)
Default Re: archive
As proposed by others, WinRAR will be the best option. If you look at the main options screen when creating an archive, you will see a drop down box where you have options to split the archive into Floppies, CDs, etc... There are also other File Splitters that can do the job...
Arun
sakumar79 is offline
- by Krow
