Old 22-09-2006, 06:50 PM   #1 (permalink)
SE><IE
Posts: n/a
Smile Where to look for JDK
I just went to SUN's site hunting for JDK (java compiler etc, to develop java applications) but was unable to hunt down JDK.
Can anyone post the direct link
Old 22-09-2006, 06:57 PM   #2 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Default Re: Where to look for JDK
Google it man..Anyway see these links
http://www.google.co.in/search?hl=en...G=Search&meta=
rakeshishere is offline
Old 23-09-2006, 06:27 PM   #3 (permalink)
http://java.sun.com/j2se/1.4.2/download.html
Arun
sakumar79 is offline
Old 23-09-2006, 07:59 PM   #4 (permalink)
Tux Fan
shaunak's Avatar
> compilers: Bluej netbeans
> Jdk 5
> J2Se 1.4.2
>J2me
>Technologies list
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 23-09-2006, 08:08 PM   #5 (permalink)
Commander in Chief
QwertyManiac's Avatar
sun.com and java.com obviously!
Harsh J
www.harshj.com
QwertyManiac is offline
Old 23-09-2006, 08:51 PM   #6 (permalink)
JGuru's Avatar
Get JDK 5.0 Update 8 & also download J2SE 5.0 Documentation
Get them from here
Use JCreator IDE There are two versions of it available, one is a JCreator Pro ver 3.50.
It's a shareware(trial version) & the other one JCreator ver 3.50 LE is a freeware.
Get JCreator Java IDE from here
@Shaunak, NetBeans & BlueJ are not Compilers!!! They are Java IDEs.
JGuru is offline
Old 23-09-2006, 09:29 PM   #7 (permalink)
In Shamful Mystery
led_shankar's Avatar
You might also need to set the classpath
http://users.ipfw.edu/udohe/JDKonDOS.pdf
led_shankar is offline
Old 23-09-2006, 10:29 PM   #8 (permalink)
SE><IE
Posts: n/a
Thanks for the help guys
Old 24-09-2006, 07:18 PM   #9 (permalink)
nishant_nms's Avatar
java.com / sun.com
nishant_nms is offline
- by Krow
