Old 22-09-2006, 08:30 AM   #1 (permalink)
whoopy_whale's Avatar
Question Improving connection speed
I'm using BSNL netone service for accessing the net.
It used to show a speed of 21-24 Kbps in the beginning.After that I used System Mechanic's Optimizing tools and got a speed of above 40kbps.
Now all of a sudden it has dropped back to 28.8Kbps.It won't increase above this speed no matter what i do.I restored the setings and applied the tweaks again,but no improvement.
Plz suggest some tools that can improve my connection speed.
Thank you...
In just two days, tomorrow will be yesterday.
whoopy_whale is offline
Old 22-09-2006, 04:31 PM   #2 (permalink)
jz2linkinpark's Avatar
Default Re: Improving connection speed
well,it could be because your previous downloads just went faster than the stuff you are downloading now, try downloading the previous stuff and see if the tweaks are working.
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
jz2linkinpark is offline
Old 22-09-2006, 05:57 PM   #3 (permalink)
Tux Fan
shaunak's Avatar
Get your true speed checked from http://www.bandwidthplace.com/speedtest/
for a 256Kbps [note the usage of capital and small letters] you should get a theoratical maximum of 32KBps. A constant speed 40KBps is Impossible even theoriticaly. you must have got an instanteneous spike up. It happen sometimes. [a lot on the cableguy's network]. Realistically after all the signal losses at the last mile ie. in the copper wire that comes from the exchance to you, [ not just a mile from your home ] you should get a maximum speed of 30KBps.
Key:
Kbps: kilobits per second [1 byte=8 bits]
KBps: kilobytes per second
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 23-09-2006, 10:22 PM   #4 (permalink)
Thanx 4 the help...I did a test and shows that...
Communications 60.8 kilobits per second
Storage 7.4 kilobytes per second
1MB file download 2.3 minutes
Subjective rating Slow
I'm getting 60.8Kbps!!!But when I connect to the net it still shows only 28.8Kbps and mine is just a dialup connection.60.8Kbps is not possible,rt?
- by Krow
