Old 03-08-2004, 08:41 PM   #1 (permalink)
Default problem with KNOPPIX
i am using KNOPPIX 3.4, every time i try to boot i have to enter
" knoppix screen=1024*768 vrefresh=60 noscsi"
or else the screen turns blank. is there a way that i can save the setting so that i dont have to enter them everytime.
secondly the resolution i get is 1152*864 and not 1024*768. and if i try to change the res to anything else the taskbar is gone.
the desktop is being cropped both at the bottom and on right.
How can i solve this
how to configure my ethernet card so i can use the net from knoppix
mahidhar is offline
Old 03-08-2004, 09:37 PM   #2 (permalink)
FooBar Guy
GNUrag's Avatar
Default Re: problem with KNOPPIX
Boot time settings for Knoppix can't be saved anywhere, as the hard disks are not mounted yet... Better option would be that you install knoppix onto a hard disk and add the kernel parameters to the /etc/lilo.conf file. using append=xxxxx option under your boot os list.
Dont use the control panel applet for changing resolution, instead use CTRL ALT num lock + key to switch reso. You'll get a virtual screen that can be scrollable through mouse.
Specially for Knoppix 3.4, open a terminal and try this....
$ xhost +
$ su -
# netcardconfig
http://web.gnuer.org
GNUrag is offline
Old 04-08-2004, 01:28 PM   #3 (permalink)
tuxfan's Avatar
Correct me if I am wrong, but there was an option in knoppix 3.3 to do this. Boot time settings could be saved. I will try to find it out.
tuxfan is offline
Old 07-08-2004, 03:57 PM   #4 (permalink)
FooBar Guy
GNUrag's Avatar
Yes please find out that... I konw one method, that is remastering your own CD
GNUrag is offline
Old 08-08-2004, 11:14 AM   #5 (permalink)
devianthulk's Avatar
i've got another problem .... my onboard audio drivers(INTEL D865GBF MOBO) are not detected...
I slip streaming possible.... i mean can i integrate the audio drivers
in the CD???
Also does it support multiple processors(hyper threading) ???
I would like to make my CD more customized for my system.....
devianthulk is offline
Old 08-08-2004, 12:53 PM   #6 (permalink)
tuxfan's Avatar
You are over-estimating my knowledge mate!! I am not an expert
There was something in its menu itself that would let you save a file on your FAT partitions. Specify it at the boot time and it would pick up the settings. I didn't pay much attention to it because I already have PCQ Linux installed on my machines. Now I will try to find it out once again.
tuxfan is offline
- by Krow
