Old 21-09-2006, 02:30 PM   #1 (permalink)
niks999's Avatar
Cool Dvd Iso
I Have got an DVD ISO.
But I want To write it in a CD AS I have No DVD-Burner.
Can Anyone tell me how to rip a DVD ISO To A CD??????
niks999 is offline
Old 21-09-2006, 03:53 PM   #2 (permalink)
gooby pls
Third Eye's Avatar
Default Re: Dvd Iso
Is your dvd iso illegal ?
Third Eye is offline
Old 01-10-2006, 10:53 PM   #3 (permalink)
Default Re: Dvd Iso
u can GOOGLE for ur answr OR, go to answer.com
cosx is offline
Old 02-10-2006, 07:42 AM   #4 (permalink)
nil_3's Avatar
Default Re: Dvd Iso
niks999 got a DVD-iso and want to just convert it into CD. Where is the question of illegality?
@ niks999
You need a software called ISOBuster or PowerISO. In it open the DVD-iso file. You will see some .VOB, .BUP and .IFO files in it. Extract these files into your HardDisc. Now in Ulead VideoStudio 10 open the .VOB files and save it as MPEG1 file(which can be later converted to VCD by Nero)or you may directly create VCD with it. This conversion will take some time depending on your Processor power; be prepared for it.
P4 3.0GHz Dual-core.
Intel 945GNT MoBo.
1GB RAM.
Seagate 160GB SATA HDD.
HP 16X Dual Layer DVD Writer.
Coloursit 450Watt SMPS with NAVTECH cabinet.
Samsung SyncMaster 740N TFT LCD 17" monitor.
nil_3 is offline
Old 02-10-2006, 10:12 AM   #5 (permalink)
gooby pls
Third Eye's Avatar
Default Re: Dvd Iso
@nil: I know but my friends have most pirated games in iso files,maybe niks999 has legal iso.
Old 02-10-2006, 11:38 AM   #6 (permalink)
Back to l33ching :)
gauravakaasid's Avatar
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
Default Re: Dvd Iso
@niks999...u can try out sumthin much simpler...use winrar to split the .iso file to 700mb parts. then wrte those files to cd. the first file will be an exe file....n d rest will b .rar ones. when u want the original iso file bak,just copy all the files into one folder n run the exe file
__________
@niks999....the above method is ok for a data image, but if the .iso file is of a video dvd then follw nil_3's method
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
Last edited by gauravakaasid; 02-10-2006 at 11:38 AM. Reason: Automerged Doublepost
gauravakaasid is offline
Old 03-10-2006, 07:54 PM   #7 (permalink)
niks999's Avatar
Cool Re: Dvd Iso
Guys,
I have a dvd iso of vista!!!
I want it in 1 cd???
Tell me solutions PLZ!!!!!
nIKHIL pATEL
bHILAI
niks999 is offline
Old 03-10-2006, 09:01 PM   #8 (permalink)
gooby pls
Third Eye's Avatar
Default Re: Dvd Iso
Try Magic ISO !
Click here for download link
Old 03-10-2006, 09:13 PM   #9 (permalink)
champ_rock
champ_rock's Avatar
Default Re: Dvd Iso
well niks999 4gb can NEVER be equal to 700mb.. so u cant have vista in one cd.. ..
however in 6 cd's u can all of vista.. but still it will not work
Registered Linux user number 400618
champ_rock is offline
Old 03-10-2006, 09:43 PM   #10 (permalink)
JGuru's Avatar
Default Re: Dvd Iso
@Niks999, You can't burn a DVD ISO image file of around 4 GB into a 700 MB CD!!!
DVD Writers prices have fallen considerably, you need a DVD Writer for sure.
So better buy a DVD Writer!!! Sony DRU 820A is a good one.
* Imagination is more important than knowledge.
-Albert Einstein
JGuru is offline
Old 03-10-2006, 10:39 PM   #11 (permalink)
gooby pls
Third Eye's Avatar
Default Re: Dvd Iso
You can't burn dvd iso on cd however you require cd's iso to burn them on cd.
Old 08-10-2006, 10:07 AM   #12 (permalink)
niks999's Avatar
Question Re: Dvd Iso
Guys I have the vista image of 733 MB!!!
Tell me some thing to fit it in one cd!!!
nIKHIL pATEL
bHILAI
niks999 is offline
Old 08-10-2006, 10:11 AM   #13 (permalink)
Google Bot
Pathik's Avatar
Default Re: Dvd Iso
wich format is it?? If its some mdf or kgb sumfin image then fuhget it
Pathik is offline
Old 08-10-2006, 10:14 AM   #14 (permalink)
gooby pls
Third Eye's Avatar
Default Re: Dvd Iso
Buy an 800MB Capacity Blank CD and then burn it.
Old 08-10-2006, 01:48 PM   #15 (permalink)
jz2linkinpark's Avatar
Default Re: Dvd Iso
you should use alcohol...most versatile and effective iso burner i know of...
i hate stupid iso image files...they are so irritatiing, it took me a whole month to find out how to use them..and finally when i did find out, i realised that i would have to pay for the software
why can't people just create compressed files instead, they're smaller and easier
I HATE ISO!
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
jz2linkinpark is offline
- by Krow
