Old 15-12-2004, 11:34 PM   #1 (permalink)
Default Samsung DVD ROM Drive is good ?
I have a Samsung DVD ROM which is attached with my
P-III computer. It was working finely. But one day I saw
that it could not read DVD disk, however it can read CD
disk tll now.
From the 'DVD Region' of 'properties' of DVD ROM drive
I found that current region shows 'Region 1'. But India
belongs to 'Region 5'. When I try to change the Region
from 1 to 5, I received an error message as per following:-
"Unable to update region setting. Please
make sure the drive contains a region 5
media and you have administration privilege."
How can the DVD drive read a DVD disk ?
---- Sadananda Singha
ssingha is offline
Old 15-12-2004, 11:50 PM   #2 (permalink)
swatkat's Avatar
Default Re: Samsung DVD ROM Drive is good ?
disk tll now.
You can change the Region Codes only 5 times for a drive.
if u have already changed 5 times,then u can use these softwares.
Try this software to read DVD of different region codes in ur drive,it's called DVD Region Code Free:-
http://www.allformp3.com/dvd-copy-so...-code-free.htm
or
DVD Ginie
http://www.inmatrix.com/genie/
http://swatrant.blogspot.com/
swatkat is offline
Old 16-12-2004, 12:32 AM   #3 (permalink)
liquid_nitrogen88's Avatar
!!!!!!!!!!!!!the ans to the topic is a big NOOOOOOOOO....we got a thread running on it:http://www.thinkdigit.com/forum/viewtopic.php?t=11413
But your qn is unrelated to the topic & ansd rightly by swatkat.
Do post the results soon........
liquid_nitrogen88 is offline
Old 16-12-2004, 08:46 PM   #4 (permalink)
..on my new rig,no country is selected rite now nd i have 5 choices remaining....
which country shud i select???
or why shud i even select...iam able to read digit DVD's....
will there be a problem while reading DVD movies??
grinning_devil is offline
Old 16-12-2004, 08:55 PM   #5 (permalink)
Another Brick in the Wall
drgrudge's Avatar
U should have no problems in reading digit DVD's, they are data DVD's.
and even i mine, no region code is selected...., yet i am able to play DVD movies and i have my DVD rom for 6 months...
drgrudge is offline
Old 16-12-2004, 09:01 PM   #6 (permalink)
...lol...then whats this hype abt area code???
whats the use??
if ur able to play DVD's for 6 months without a problem...why r these codes made???
nd i think i shudn't select ny one of them.....rite na>?
Old 16-12-2004, 09:25 PM   #7 (permalink)
drgrudge's Avatar
whats the use??
Dude, if u have a DVD player, then region code is important.
These were made for DVD players, not DVD rom's.
and why these region code were made, i have no idea.
drgrudge is offline
Old 16-12-2004, 10:46 PM   #8 (permalink)
So that (Po rn) DVDd's Illegaly created and copied in Asia do not go to other continents .Similarly DVD's illegaly copied outside Asia do not run here.
Take it as (por n) or anything else. You know Asia is the piracy supermarket na ?
Bomb is offline
Old 17-12-2004, 03:31 AM   #9 (permalink)
ohh...come on grinnie....u rnt a novice any more....
region code was initially working well for DVD players but now it can be easily neutralised with a chip add on....
region code in DVD ROMS are easily circumvented by above mentioned softwares...and many others...just google it.
Also newer DVD ROMS are non region coded....
overall,i think the idea of region codes really s@#$%......
Old 17-12-2004, 06:58 AM   #10 (permalink)
..ya definately...region code do S****...!
if that was meant to curb piracy...then its not doing ny good....
specialy in India.....
- by Krow
