Old 19-09-2006, 11:56 PM   #1 (permalink)
SE><IE
Posts: n/a
Default Digit CD can't run!
okey guys I installed autopatcher today and now whenever I pop-in the november 2005 / december 2005 / january 2006 / February 2006 CD. Nothing happens but HDD LED glows continuously.
Neither the discs are bad, nor the DVD-ROM, cuz discs used to work till tomorrow and DVD-ROM can read other discs e.g august/september 2006.
A strange thing is that DVDs do work fine.
Any help.
I checked with Isobuster and it showed "No media present" hell... whats happening!!
Old 20-09-2006, 12:10 AM   #2 (permalink)
-- No Easter Eggs here --
hemant_mathur's Avatar
Default Re: Digit CD can't run!
Have u tried system restore ?
E6850 3.0 Ghz, 4gb 667 Mhz RAM, Asus p5n Esli Mobo, Nvidia 8600GT 512mb, 400gb WD HDD, Samsung Syncmaster 920NW, Vista x64
hemant_mathur is offline
Old 20-09-2006, 11:14 PM   #3 (permalink)
SE><IE
Posts: n/a
System restore is a big pile of stinky sh*t. It didn't uninstall anything much but it did delete everything I downloaded in the last 12 days. Aaahhhhh..... my 500MB data is gone and I don't even remmeber the links.
Is there any way by which I can get my data back (afterall only the links have broken, the data still resides on my HDD)
Old 21-09-2006, 12:12 AM   #4 (permalink)
Super Hero - Super Powers
n2casey's Avatar
Just burn that 500 MB data on any RW & then use System Restore.
n2casey is offline
Old 21-09-2006, 12:42 AM   #5 (permalink)
Get ur data back using any file recovery sw like easy recovery.
Old 21-09-2006, 06:01 PM   #6 (permalink)
SE><IE
Posts: n/a
You didn't get it. I have already lost my data. I gave a try to system restore hoping it will solve the "CD problem" but It deleted my 500MB data, winamp and virus definition files (downloaded) leaving the royale theme (installed by autopatcher) etc untouched.
Anyways I was err am looking out for some data recovery software which can retrive that data from my hard-disk. Perhaps a trial-version which can actually recover, not just show what most 'em do.
Old 21-09-2006, 06:40 PM   #7 (permalink)
Beware of the innocent
ilugd's Avatar
restoration works ok. Just be sure to run it from a drive which is NOT the one you want to restore data from
Life is too short. Have fun.
ilugd is offline
Old 21-09-2006, 09:58 PM   #8 (permalink)
SE><IE
Posts: n/a
Well... I've already done enough bad. I had restored but when I found I was missing what I shouldn't and was not missing what I should (autopatcher); I undid the changes due to system restore. Theoritically, I would have been back to the condition where I actually was. But It wasn't that way, my 500MB data was still missing.
Old 21-09-2006, 11:36 PM   #9 (permalink)
ilugd's Avatar
Sorry, I meant this
http://www.snapfiles.com/php/downloa...g=234966&loc=2
ilugd is offline
Old 22-09-2006, 12:36 AM   #10 (permalink)
SE><IE
Posts: n/a
Thanks all but I am unable to restore my PC to that condtion again. moreover Some of the programs are now only "partially installed". Gotta reinstall the OS.
Mods please lock this thread.
- by Krow
