Old 17-09-2006, 10:11 PM   #1 (permalink)
wwwescape's Avatar
Default Undeleteable Folder ...
Recently I installed the MegaPatch for Cricket 2005 which was available for download at www.cricket2005.org. I uninstalled it later but it's folder and shortcut folder remain and cannot be deleted at all. It has become really annoying.
I get the following Message Box:
Error Deleting File Or Folder
Cannot Delete File: Cannot read from the source file or disk
I've tried reinstalling and uninstalling, but I get the same result. Please help !!!
wwwescape is offline
Old 17-09-2006, 10:35 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: Undeleteable Folder ...
Install Unlocker, after installing it right-click on the folder and select Unlocker and then select Delete in drop-down box. If it ask for delete on next reboot, accept it.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 17-09-2006, 10:48 PM   #3 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
use delete doctor ...dwnld it from here
http://www.diskcleaners.com/files/deletedr.exe
rakeshishere is offline
Old 17-09-2006, 10:48 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
yes unloker will solve ur problem..n it is free.
u may also delete the folder in safe mode.I think ur problem will be solved nw.
ravi_9793 is offline
Old 17-09-2006, 11:27 PM   #5 (permalink)
!FREEWARES!
Akshay's Avatar
If unlocker does not wrk, try Freefile
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is offline
Old 18-09-2006, 11:21 PM   #6 (permalink)
wwwescape's Avatar
Thanks y'all. Unlocker really helped ... Thanks again.
- by Krow
