Old 16-09-2006, 10:53 PM   #1 (permalink)
Exclamation Is it a Wise Option To Buy DVD spindles ?
guys would like ur view on this ...
when we buy loose DVD's say 5 or 6 ... usually the guys takes from a 100 Spindle counts & gives u ..... he does this for every customer .....every time ... he Removes,counts & replaces ..... there by scratching & damaging a Few in the process ...i have also noticed that ... when buy loose (5 0r 6 ) .... edges of few DVD looks badly handled or scratched
instead do u think its better options ... buy a 10 or 25 spindles ... as it comes company sealed ... there giving no chance for that guy to Damage ur DVD's
pls comment on this
vinyas is offline
Old 16-09-2006, 11:29 PM   #2 (permalink)
Another Brick in the Wall
drgrudge's Avatar
Default Re: Is it a Wise Option To Buy DVD spindles ?
DVDs are my assets. I take a lot of pain to get the data for the DVDs, so I don't compromise on petty things like pouches/spindle packs. I usually buy the 10 DVD pack, so for that time till I burn the DVDs it's safe. Later on I have them in my pouch.
IMO buy pouches man. It costs only 40 bucks and you can store 48/32 DVDs.
drgrudge is offline
Old 17-09-2006, 01:28 AM   #3 (permalink)
I buy in packs of 25/50. That too only if they're sealed. Later I put them in a pouch. You're right about the dealers scratching the DVD's while handling them. Best way to avoid it is to buy a sealed pack.
drvarunmehta is offline
Old 17-09-2006, 09:29 PM   #4 (permalink)
TechGuru#1's Avatar
Wink Re: Is it a Wise Option To Buy DVD spindles ?
Even If i get the Loose DVD's usually I make the selection of which particular DVD's I would take/buy!
In a cake/spindle of 100's the vendors often would give u the discs from the top of the spindle,but i just take out the first 5-10 discs from the top & therafter only begin to choose the disc,which r more or less in pristine stage.Not only that ,i make a double check from that lot too for damage/scratches/finger smudges,etc!....
........& after all that, i get the DVD' same 2 same as in the 10/25 box packs!
TechGuru#1 is offline
Old 17-09-2006, 09:54 PM   #5 (permalink)
yeah... looks as though buying spindles is right way to go about it
vinyas is offline
- by Krow
