I want to buy a new 512MB RAM,so I ask my dealer about it he said that 512MB RAM at 266Mhz (my motherboard supports only DDR SDRAM at 266MHz) will cost me around Rs.2600.But recently my friend has brought a 512MB DDR RAM for Rs.1900.Then why the cost of DDR SDRAM is higher.
I have a Compaq branded PC.
PLease tell me..?
Thanks
Actually,i want 512MB DDR SDRAM @ 266MHz,so that it can work with my existing 128MB RAM.I am from Dehradun,& here a 512MB RAM @ 266 MHz is difficult to find & i have a branded Compaq Presario,so my dealer said that he will order new RAM from the Company Headquaters.
Also please tell me the exact difference between DDR & DDR SDRAM,i am bit confused
Do check out www.npithub.com for the l8est prices in nehruplace!!! >-
My Favourite Blogs -
http://Mysticgadgets.com | Gadget Weblog
http://Mantosuperman.blogspot.com | Styleing Tips, And Evrythign You Need
