Old 16-09-2006, 10:06 AM   #1 (permalink)
shyamno's Avatar
Wink connecting two TV with one Cable connection.
can anyone tell me how to connect two tv with one cable connection.Please reply soon.
shyamno is offline
Old 16-09-2006, 12:46 PM   #2 (permalink)
clmlbx's Avatar
Smile Re: connecting two TV with one Cable connection.
You Just Have To Buy The Stuff That Will Divide Ur Main Cable Connection Into Two . That U Can Get In Any Electronic Shop [rs 10 Or 15 Stuff ] And Cable Wire [of Length How Much U Need To Extend It To Ur Anothe T.v ] . I Don't Remember What That Stuff Is Called But U Will Get It When U Will Talk The Shop Keeper Of Elctronic Shop And Explain What U Have To Do .
clmlbx is online now
Old 16-09-2006, 06:28 PM   #3 (permalink)
shyamno's Avatar
Default Re: connecting two TV with one Cable connection.
can any one tell me is that possible to divide the cable without using any RCA(or RF) Cable splitter.
shyamno is offline
Old 16-09-2006, 07:17 PM   #4 (permalink)
Yes you can, by using a suitable induction coil and amplifier. But why, when you can use a simple and cheap splitter?
V.Prem Kumar
janitha is offline
Old 17-09-2006, 12:51 PM   #5 (permalink)
shyamno's Avatar
how much a splitter will cost? Which splitter must be bought any specification?
shyamno is offline
Old 17-09-2006, 05:46 PM   #6 (permalink)
nishant_nms's Avatar
u can do it by just joining two wires on the end of the cable wire
nishant_nms is offline
Old 17-09-2006, 06:08 PM   #7 (permalink)
hmmmmmmmmmmmmm's Avatar
no need splitter jus cut it...n join wit plaster...n sum signal will drop...
hmmmmmmmmmmmmm is offline
- by Krow
