Old 14-12-2004, 04:42 PM   #1 (permalink)
Default Symphony with SNDREC32.EXE
Hi guys watch this great flash that shows Symphony with SNDREC32.EXE
http://www.ebaumsworld.com/windowsnoises.html
Do u Linux guys have something like that? Nah !!
DiGiTaL-NoViCe is offline
Old 14-12-2004, 04:50 PM   #2 (permalink)
FooBar Guy
GNUrag's Avatar
Default Re: Symphony with SNDREC32.EXE
Shall i start listing things that Linux guys have and Windows guys dont have ?
http://web.gnuer.org
GNUrag is offline
Old 14-12-2004, 05:05 PM   #3 (permalink)
Linux lovers..keep listing..
As you enter this life,I pray you depart
With a wrinkled face,And a brand new heart.
-- U2\'s Love and Peace or Else (HTDAAB)
svenkat83 is offline
Old 14-12-2004, 05:13 PM   #4 (permalink)
tuXian's Avatar
The other day I saw a video in ASCII Art that had great sound effects and visual appeal. I dont rem the name will check and then tell. No playing with a barebone recorder like SNDREC.
BTW whats so great about SNDREC? its a useless piece of software that can record sounds of upto a minute only.
I think the composer had no work to do so just killed time ending up in such a silly thing.
You know it's love when you memorize her IP to skip DNS overhead.
tuXian is offline
Old 14-12-2004, 06:40 PM   #5 (permalink)
vysakh's Avatar
no thanks
Incompatible message format
vysakh is offline
Old 14-12-2004, 09:48 PM   #6 (permalink)
someone may not want things to be listed out of fear. But truth will remain truth.
Its your attitude not your aptitude that determines your altitude.
tuxly is offline
Old 14-12-2004, 09:53 PM   #7 (permalink)
tuXian's Avatar
This is at an airport. Two terminals were put to display info. The left was running on Linux and the other was on windows. Then something happened after sometime. Lets see what happened
tuXian is offline
Old 14-12-2004, 10:52 PM   #8 (permalink)
King of my own Castle
freshseasons's Avatar
Seems another war of windows Vs Linux is inevitable.
@DiGiTaL-NoViCe please refrain from using provocative language . Even there are lots of Legal registered windows Xp user but fighting with Linux is no solution . Linux definatly has some of the advantages that windows dont seem to have and windows some which linux dont seem to have.
Both are good and definatly have their uses.
freshseasons is online now
- by tv6952
