I m using DIVX 6.3 pro for COnverting MOvies to DIVX in 700 MB I m getting Problem with Sound.. i.e Audio Sync only with movies.. I do not get this prob with Songs The Same thing is Happening with NERO 7 (Nero Recode DVD to mp4)
Also Is It Possible to convert dvd/movie to DIVX through NERO RECODE? is there any Plugin i Need?
I suggest you use the XviD codec over DivX. It gives slightly better results for the same file size. Use AutoGK to do the same. I've never had any AV sync errors with it.
