Old 15-09-2006, 02:41 PM   #1 (permalink)
Cool ISO file bruning to CD
hi everybody,
on the september Digit issue i received a mandriva 2006 in ISO file. i had a problem burning ISO to CD so i can installed in my PC. i have dell machine with 2.4 GHz, 512 MB RAM and 40GB hard disk, DVD combo with nero smart and OS is winXP sp2. hope u guys there will help me to write this ISO to CD.
thanks in advance.
Tshering Dorji
Nimtshey is offline
Old 15-09-2006, 02:43 PM   #2 (permalink)
Beware of the innocent
ilugd's Avatar
Default Re: ISO file bruning to CD
what was the error?
Life is too short. Have fun.
ilugd is offline
Old 15-09-2006, 05:34 PM   #3 (permalink)
Originally Posted by Nimtshey
hi everybody,
thanks in advance.
the iso format is also supported by nero by its all new versions. open the file
by right click on it. give the path of nero.exe and click ok
check box that open same format file by same application
any problem: kurademahesh@rediffmaiil.com
from mahesh kurade
Mahesh Kurade is offline
Old 21-09-2006, 04:53 PM   #4 (permalink)
altimate's Avatar
Open up ur nero.
There should be option as
"BURN IMAGES TO CD"
It would open the dialogbox for *.nrg and *.iso
then open the iso file and continue to burn.....
altimate is offline
Old 21-09-2006, 06:32 PM   #5 (permalink)
use UltraIso... it also uses Nero Api.. totally rocks for burning
vinyas is offline
- by Krow
