Old 15-09-2006, 09:32 AM   #1 (permalink)
nikhilrao's Avatar
Default any registry trick for changing this ?
I want to change the default location of my OutlookExpress AdressBook from its default location on my C drive to my E drive, so that in case of a reformat, I dont loose all my data. Is there any Tweak or Registry trick how I can make this ???
nikhilrao is offline
Old 15-09-2006, 09:41 AM   #2 (permalink)
Distinguished Member
anandk's Avatar
Arrow
The Windows Address Book used by Outlook Express is normally located in the \Application Data\Microsoft\Address Book Folder
do this :
click start>run>regedit
go to HKEY_CURRENT_USER\Software\Microsoft\WAB\WAB4\Wab File Name
in the Data col u will c the location address.
change it to the location u want.
reboot.
hope it helps !
incidentally, such registry tricks r avlble in an xclnt e-book "Windows Registry Guide" from www.winguides.com
do check it out ! its a worthwhile download for those wanting to learn registry and registry hacking.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 15-09-2006, 10:01 AM   #3 (permalink)
anurag_online's Avatar
Default Re: any registry trick for changing this ?
anandk thanks bahi even i needed that too... worked for me...
"M I Wrong???? Na I Can't be!!!" Feel Best Of Yourself is the Key Of Success...
anurag_online is offline
Old 16-09-2006, 07:53 PM   #4 (permalink)
nikhilrao's Avatar
Ya It worked. This forum ROCKS. Thanks.
- by Krow
