Old 14-09-2006, 06:20 PM   #1 (permalink)
Console Junkie
aditya.shevade's Avatar
Default Registry Writing Problem
Hi
I have a question. When I log on to a PC with a limited user account and try to insert string values, I can do that. Whenever I try to insert a new key or DWORD or the other keys, a message is displayed saying "Error Writing to the Registry". Is there any way to enable the writing in the registry, if you don't have the admin status.
--- Console Junkie
aditya.shevade is offline
Old 15-09-2006, 06:42 PM   #2 (permalink)
Console Junkie
Default Re: Registry Writing Problem
Where are you Mr. Vishal? What happened?
--- Console Junkie
Old 15-09-2006, 08:26 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
U hv to set the permissions for the keys in regedit!
Login as administrator and open regedit and right-click on the key (on which u want to give permissions) and select "Permissions" and here u can give permissions to the user
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 15-09-2006, 10:56 PM   #4 (permalink)
Console Junkie
What if I am not the administrator? Can I do this in any other way?
--- Console Junkie
Old 15-09-2006, 11:20 PM   #5 (permalink)
Microsoft MVP
I don't think its possible if the administrator has disabled these rights.
u may try 3rd party registry editor, may be those s/w allow u to create ur desired keys?
Old 16-09-2006, 12:19 PM   #6 (permalink)
Exclamation Re: Registry Writing Problem
You need admin access to edi registry, otherwise what would be the use if any user can access the registry, security of any system would go down the drain.
slagad is offline
- by Krow
