Old 14-09-2006, 07:22 AM   #1 (permalink)
Default re-encode avi file
hi,
i've few divx compressed .avi file...which i need to re-recode so that i can burn them on a single 4.7 gb dvd?? please suggest some solution.....
thax
jack// ani is offline
Old 14-09-2006, 09:02 PM   #2 (permalink)
nil_3's Avatar
Default Re: re-encode avi file
If possible try to avoid re-encoding as far as you can. Re-encoding should further degrade it's quality. Just make Data-DVD and enjoy in a DivX player.
If re-encoding is almost a necessity, then use Ulead Video Studio, do the necessary editing and convert it to DVD-Video.
P4 3.0GHz Dual-core.
Intel 945GNT MoBo.
1GB RAM.
Seagate 160GB SATA HDD.
HP 16X Dual Layer DVD Writer.
Coloursit 450Watt SMPS with NAVTECH cabinet.
Samsung SyncMaster 740N TFT LCD 17" monitor.
nil_3 is offline
Old 14-09-2006, 10:40 PM   #3 (permalink)
thanks for reply. you got me wrong....i do not intend to convert it into dvd video. all i need is to re-encode the avi file to avi itself so that file gets more compressed.....so that i can burn my classified collection into single dvd.
Old 15-09-2006, 06:14 AM   #4 (permalink)
nil_3's Avatar
Use Dr. DivX, play with parameters like Length-bredth or Bit-rate,(though there are several other factors) and you will get the intended file-size.
Intel 945GNT MoBo.
1GB RAM.
nil_3 is offline
- by Krow
