Old 13-09-2006, 10:05 PM   #1 (permalink)
Default Adding *.VOB files?
Hello,
I want to add *.VOB files (these files are found in video_ts directory in DVD movie)...I had used "open video joiner" and "vobedit0.6" but of no use..
My aim is to extract 2 movies in a DVD (having 3 movies) and 1 movie in a DVD (having 3 movies) and to burn these 3 movies in a DVD.
Dongay Rajasekhar Panda is offline
Old 14-09-2006, 06:16 AM   #2 (permalink)
nil_3's Avatar
Default Re: Adding *.VOB files?
You have to employ the following pocedure. I think this is the only procedure. If otherwise, please anybody inform us.
1. From the 3 movie DVDs extract your intended movies separately by Nero Recode > Compile a DVD.
2. Merge the DVDs with the software DVD Remake PRO. You must have only PRO version. DVD remake PRO will merge them with its own menu.
3. If you want, you can replace this menu with a still/motion menu created by you by any standard menu editing softwares. This tutorial is available at its site.
P4 3.0GHz Dual-core.
Intel 945GNT MoBo.
1GB RAM.
Seagate 160GB SATA HDD.
HP 16X Dual Layer DVD Writer.
Coloursit 450Watt SMPS with NAVTECH cabinet.
Samsung SyncMaster 740N TFT LCD 17" monitor.
nil_3 is offline
- by Krow
