13-09-2006, 08:55 PM
elctricity
Guys plaees help me . tell me what will happen in this circuit diagram and please support your answer with a reason.If you wnat to explain it with the help of any law then you can do so.
Circuit diagram is at
http://s68.photobucket.com/albums/i2...gAnch=imgAnch1
if you want to ask anything else then PM me.
The secret of creativity is knowing how to hide your sources.
Albert Einstein
13-09-2006, 09:20 PM
The Devil
Re: elctricity
Where did you find this strange ckt diagram?
Both the batteries will drain out and no current will pass through the resistor. If you forget the resistor, then basically the circuit consist of 2 batteries connected end to end. That will drain out the batteries as no resistor is in the path. Now when you connect the resistor in parallel, no current will pass thru it as the batteries are already shorted (current always takes the path having the lowest resistance.)
14-09-2006, 11:03 AM
Re: elctricity
thanks blackpearl for your reply but i still expect some more answers as this is the controversial topic going on between my friends.
Now i want to ask one thing if you treat the resistor as a wire?
another thing if emf of one battery is greater than other than what?
Albert Einstein
14-09-2006, 11:50 AM
The Devil
Re: elctricity
If you change the resistor with a wire i.e. a conductor, then both the batteries will again discharge but this time via the wire as now the wire becomes the path of least resistance. It does not matter if the batteries have different emf. When you add 2 batteries (of different or same emf) in series (first case), then the resultant emf will be the sum of 2 emfs. In the second case (resistor replaced by wire), you have 2 batteries that are both shorted with the same wire. So both will discharge individually through the wire and the total current passing thru the wire will be the sum of currents due to both the batteries.
Read about superposition theorem.
http://www.allaboutcircuits.com/vol_1/chpt_10/6.html
http://hyperphysics.phy-astr.gsu.edu...ic/suppos.html
14-09-2006, 01:49 PM
-The BlacKCoaT Operative-
Re: elctricity
wanna let me in on the hidden agenda or somethin..
what exactely is being attempted here...
if u want to knwo if current passes thru the resister then yes it will but in very low qualities..
both battries will just behave like a resister(low if in series and high in ||el) to each other.. the resistence being equal to the 'inter resistance' of the opposit battry....
i still dont get what is it that u want to know?
14-09-2006, 03:27 PM
Re: elctricity
@ rollercoster
i want to know what willhappen in the case of the circuit diagram i have provided, as a link. check it and then tell me , please sate the reason for it.
This is for to other members that one reply i have recieved from my friend is that nothing will happen in circiut as resultant emf will be equal to 0.
Albert Einstein
14-09-2006, 03:57 PM
Re: elctricity
r u electrical engineer?
14-09-2006, 04:47 PM
The Devil
Re: elctricity
Originally Posted by sariq
Let me rearrange your circuit diagram. see attached image. it short circuitng batteries a heavy current will flow burning the wire, if wire is thick one of the battery will explode. if batteries have different ratings, battery with less current carrying capacity will explode. if instead of resistance, you are fixing wire - both batteries will explode
Batteries don't explode on short ckting. The wires will heat up due to heavy current flow and might burn or melt, whatever. Nothing more than that.
14-09-2006, 08:56 PM
Re: elctricity
Friends i will post more queries and questions about this tommorow as i am going to ask this from any teacher by that time keep on thinking of new possiblities.
and by the way naveed i am not electrical engineer rather i want to become computer software engineer ( application and operating system programmer). if you can tell me anything i need to know that will help in my aim then i wil be thankful to you.
Albert Einstein
14-09-2006, 09:56 PM
Console Junkie
Re: elctricity
Nothing will happen if the batteries are of low emf as 1.5V (normal dry cell) exept that they will heat a lot. If they are of higher emf then they will heat even more and may result in melting of the wire. Why do you want this anyways?
--- Console Junkie
15-09-2006, 04:23 PM
Re: elctricity
i wnat to know because my friends were not ready to accept what i was saying that i wanted your opinion and now everything is fine.
Albert Einstein
15-09-2006, 05:46 PM
Tux Fan
Re: elctricity
The resistor load will be divided on both the batteries. Little heat may be caused depending on the resistance.Nice way to waste 2 perfectly good battries.
Cheers
Shaunak
Feel free to PM/email me.
15-09-2006, 11:28 PM
"The RaCaLaNGeL"©
Re: elctricity
if the two batt are of diff emf's then the voltage across the load res will be the diference of the two voltages...since the currents are flowing in opp direction so they will cancel each other hence only the differential current will flow....if the two sources are equal then potencial across load will be nil since both currents will cancel each other completely....
Without sorrows happiness would be boring!
16-09-2006, 10:05 AM
Re: elctricity
What i mean to say is that in this case battery will blow up as soon as you will connect the circuit,instantly
Albert Einstein
17-09-2006, 12:11 AM
Re: elctricity
this is dumb. there is no question to be answered...
and NO the batterys wont blow "instantly" and NO there will be no heat at the resister as the current will be too low. in case some people have forgotten electricity has the basic property of following the shortest path(less resistance=less work).. for eg lightening in sky.
dude bill william gates... post an accurate question then maybe some physics can be exchanged
17-09-2006, 10:23 PM
Re: elctricity
but dear rollercoaster i have not mentioned that it is resistor it is conductor and a wire is also a conductor. This diagram is simple, short-circuiting of batteries, don't u think so.
Albert Einstein
18-09-2006, 11:45 PM
Re: elctricity
<sarcastic>
thatz cool... my mistake.. i thought u were familiar with electronic symbols. but u r NOT.. i saw a resister symbol and thought right, how dumb of me!
</sarcastic>
u have to brush up ur electronics to atleast recognising the simbles before attempting to go deep physics diving.
see this http://en.wikipedia.org/wiki/Resistor
(just to make myself clear the above is a hyperlink used to point to a webpage, u C L I C K on it)
19-09-2006, 06:24 AM
Commander in Chief
Re: elctricity
Looks like he had changed his question midway Rollercoaster.
and thats creating all the confusion now.
Harsh J
www.harshj.com
19-09-2006, 08:33 AM
#19 (permalink)
Re: elctricity
i have not changed my question qwerty, question is same.
@ rollercoaster
another thing i know about symbols if you look clearly at the diagram then i have drawn a symbol for a resistance i accept that ,but i have marked it as a conductor. and evry conductor has resistanace and wire too is conductor.
Albert Einstein
19-09-2006, 08:34 AM
#20 (permalink)
Re: elctricity
@william: you should ask like that: what if I short circuit a battery?
every wire have some resistance. in your case (short circuit) this resistance matters. current is limited by wire resistance +battery internal resistance. in your case if you neglect wire resistance current through each battery = battery voltage/battery resistance. current through central resistor is difference of these two.
19-09-2006, 08:37 AM
#21 (permalink)
Re: elctricity
i agree with you but i don't think there was any thing wrong in that question . your question is also correct.
Albert Einstein
20-09-2006, 06:10 PM
#22 (permalink)
"The RaCaLaNGeL"©
Re: elctricity
ok!in the end which question is proper?
20-09-2006, 07:21 PM
#23 (permalink)
Re: elctricity
You can consider any of the question, the one asked by me or the one asked by what i was saying that in this case battery will blow up, and for more i wanted opinion of other members.
Albert Einstein
24-09-2006, 02:59 PM
#24 (permalink)
"The RaCaLaNGeL"©
Re: elctricity
the bat wont blow up if dc<=3V.
24-09-2006, 09:01 PM
#25 (permalink)
Re: elctricity
can you tell why?
Albert Einstein
26-09-2006, 11:59 AM
#26 (permalink)
Re: elctricity
there is no specific method to tell if and when a battery will blow up or not.
it depends on the amount of pressure created inside the battery container, due to gases or expanded matter because of heat generated during large current transfer upon short circuit.
this question does not have an accurate answer because the subject matter is too broad and little specification/inforamtion has been provided.
it is like saying when will a rubber balloon blow up when filling with gas?
you need to know more abt the baloon and the rate of gas induction and environment conditions to tell when the balloon goes pop!
26-09-2006, 02:26 PM
#27 (permalink)
"The RaCaLaNGeL"©
Re: elctricity
as rollercoaster said,it will depend on what type of bat u use.....
Search this Thread |
