Old 13-09-2006, 07:33 PM   #1 (permalink)
56561's Avatar
Default time taken to burn
I want to know how much time it takes to burn a 4.6 gb data using a dvd burner using different speed . Also I want to know time takes to burn for CD also at different speed .
thanks ,
56561 is offline
Old 13-09-2006, 08:42 PM   #2 (permalink)
Default Re: time taken to burn
5 mins @ 16x
i use only SOny Media ... which is best so far wat i have used
vinyas is offline
Old 13-09-2006, 10:36 PM   #3 (permalink)
vikasg03's Avatar
5 min??? impossible.... I use moserbare DVD @16x and my LG dvd writer takes 45-50 min to burn 4.5 GB data in DVD...
vikas
Vikas
vikasg03 is offline
Old 13-09-2006, 11:05 PM   #4 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
My Sony DVD Writer takes 8-10 minutes in writing a 4.5 GB DVD
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 13-09-2006, 11:09 PM   #5 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
My LG DVD writer takes 5.6 min to burn 4.5GB of data on mosaerbaer DVD
rakeshishere is offline
Old 14-09-2006, 04:30 AM   #6 (permalink)
Desperado's Avatar
Angry Re: time taken to burn
hey i m GUESSING .. it depends on the media you use... i use MOSAER bear and it takes 50 - 60 mins to burn a dvd.. i m planning to try some other media like sony etc some time soon
i have a sony dvd writer
Friendly Neighbourhood,
Shahid
Desperado is offline
Old 14-09-2006, 08:23 AM   #7 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
^^ How do you people live with 50-60 minutes to burn a DVD! There is definately something wrong with your drives! Check if DMA is enabled! It should take somewhere around 6 minutes to burn @ 16x. My BenQ DW 1650 takes a little under 6 minutes to burn a full DVD.
@vinyas: 5 minutes is impossible (unless you have an 18x writer). You must not have burned a *full* DVD.
kalpik is offline
Old 14-09-2006, 08:56 AM   #8 (permalink)
champ_rock
champ_rock's Avatar
check ur buffer's .. if they continuosly decline and then move back up then there is some problem.... that results in a major time lag..
Registered Linux user number 400618
champ_rock is offline
Old 14-09-2006, 09:49 AM   #9 (permalink)
gooby pls
Third Eye's Avatar
My Benq CD/DVD Writer takes 15-20 min to burn 4.35GB of Data.
Third Eye is offline
Old 14-09-2006, 05:53 PM   #10 (permalink)
thetopcyborg's Avatar
hey, i also have the same drive......to burn moserbaer 4.7gb at 8x, it takes 20-30 mins......y is this??? and DMA fails whenever i enable it
thetopcyborg is offline
Old 14-09-2006, 06:19 PM   #11 (permalink)
kalpik's Avatar
8x should take around 12-15 minutes. For your DMA problem, right click on your primary/secondary IDE channel (depending on which channel your writer is connected to) and select un-install. Then reboot. Windows will install the IDE channel again. Then try enabling DMA.
kalpik is offline
Old 14-09-2006, 07:37 PM   #12 (permalink)
coolsunny's Avatar
mine takes 8-9 minutes at 8x speed.
AMD X2 260, GA M68MT-S2P, Gskill RipjawsX 4GB, 500Gb Seagate, Cooler Master eXtreme Power Plus 600W, Altec Lancing atp3, Samsung B2230 TFT, Numeric Digital 600 EX-C UPS.
coolsunny is offline
Old 14-09-2006, 09:04 PM   #13 (permalink)
Burnt 3 DVD Today ... movies of size 4.35 gb
i am using Sony DVD+R Ver 2.0,16x media
DVD 1 : 5.10 mins
DVD 2: 5.07 mins
DVD 3 : 5.12 mins
using nero 7 .....
average it takes 5 mins for me ... i dont like moser baer media ... had problems finalising the DVD.... been using sony for almost 6 months now ... no probs at all...though Media is a touch expensive .... dont mind paying the price as long they maintain quality
vinyas is offline
Old 15-09-2006, 09:18 PM   #14 (permalink)
Pragadheesh's Avatar
Post Re: time taken to burn
DVD @ 8x-12mins
@ 4x-16mins
Cds at 32x-4mins using sony dvd writer & Nero 7
__________
also frenz , is it possible to find the SPEED at which a CD/DVD is burnt?
Please tell how to find it??
Pragadheesh is offline
Old 15-09-2006, 10:33 PM   #15 (permalink)
Super Hero - Super Powers
n2casey's Avatar
My SONY DVD RW takes 6.2 -7.0 min for writing 4.6 GB on SONY DVD-R at 16x
n2casey is offline
Old 16-09-2006, 11:09 AM   #16 (permalink)
56561's Avatar
I Should Try Sony Instead Of Moserbear From Now On .....
56561 is offline
Old 16-09-2006, 10:42 PM   #17 (permalink)
sony rules for me..... burnt more than 100 sony DVD .... not even one coaster
vinyas is offline
Old 17-09-2006, 11:04 AM   #18 (permalink)
Old 17-09-2006, 11:09 AM   #19 (permalink)
Commander in Chief
QwertyManiac's Avatar
Doesnt your burner show what speed its burning at? ... ?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 17-09-2006, 11:30 AM   #20 (permalink)
i have some old cds (of just 100 MB)for which i want to find the speed at which its burnt so dat i can do multisession over it?
Any ideas?? Plz help me frenz..
Old 19-09-2006, 04:33 AM   #21 (permalink)
Desperado's Avatar
Unhappy Re: time taken to burn
.. give us a resolution to minimize this issue ..? kalpik's idea comes close ....how do i find which channel my dvd is set to..
-- can u help me with one more issue .... whenever i play a dvd/ cd the sound is slightly blurry/echoes ... but when i play a movie saved on my harddsik.. it sounds perfectttt...
any suggestions why this is happening.. a step by step setting for IDE channels would be appreciated...
Shahid
Old 19-09-2006, 07:29 AM   #22 (permalink)
Let the music play.....
djmykey's Avatar
I used my LG GSA-H10N on a USB 2.0 external case.
DVD used Princo (dont frag me was testing this setup)
DVD burned at 4x in 13 mins flat. No buffer problems or nothing. Just smooth.
djmykey is offline
Old 19-09-2006, 07:53 AM   #23 (permalink)
kalpik's Avatar
Hmm.. You can use Nero Info Tool (under nero toolkit) to find out the channel your writer is connected to. And your second problem is also due to DMA most probably..
kalpik is offline
Old 19-09-2006, 12:23 PM   #24 (permalink)
The Researcher
My sony DVD writer takes about 10 minutes for writing
Ramakrishnan is offline
Old 19-09-2006, 12:39 PM   #25 (permalink)
i reinstalled my drive but the time taken is same....moreover, the time taken to burn a Sony cd-r at 48x is 2mins.....
mommy!!!!!!1
and btw, i hv two drives, a really old samsung as master and the benq as slave.....i want to interchange the two i.e want to convert benq as master and samsung as slave....will i be able to do that just by changing the ide connectors?????
and will it affect my drives in any way?
Old 19-09-2006, 03:12 PM   #26 (permalink)
kalpik's Avatar
^^ You dont have to change the connectors.. Just change the jumpers (read about them in the manual, they are next to the IDE cable). And 2 mins @ 48X for a CD is perfectly normal.
kalpik is offline
Old 20-09-2006, 03:32 AM   #27 (permalink)
Desperado's Avatar
hey kalpik, help me out with my second issue man ..!!!
Shahid
Old 20-09-2006, 06:26 PM   #28 (permalink)
djmykey's Avatar
@Desperado - Tell me how u play a movie frm a dvd, I mean player and all. Coz u might b using a diff player and the player might b having a diff sound setting. So check that and then reply.
djmykey is offline
Old 20-09-2006, 07:21 PM   #29 (permalink)
Desperado's Avatar
thx djmykey .. its vlc player ..i was using this player for abt 2 month... never had this problem earlier.. ... my dvd rw is set to secondary ide channel.. and when i change it to DMA .. i cant even see the media files..
only if i revert it back to PIO mode dat i can play the movies.. but as i said the sound echoes..
Shahid
Old 20-09-2006, 08:40 PM   #30 (permalink)
djmykey's Avatar
I dunno abt vlc but u can check if u r using some equaliser or some effects that might b making some hall effect or sumthing.
Dont change the PIO mode to DMA the optical drive wont work. Optical drives work on PIO mode only.
djmykey is offline
- by Krow
