Old 13-09-2006, 12:06 PM   #1 (permalink)
Thor's Avatar
Lightbulb Advice on Project.
Dear frnds,
I am a 3rd computer science Engg. student.I am thinking abt doing a project.
I am thinking of developing a tool using c++ which does the following:
1>Applies various (*) tweaks to windows XP using the Registry
2>Tells which s/w are installed in the pc
3>Tells item in the startup
4> does othr various small things one can never do in XP without going berserk with it.
is this acceptable as a project?
Thx.
Beware of my Wrath Mortals, Thou hast no choice.
Thor is offline
Old 13-09-2006, 08:37 PM   #2 (permalink)
bukaida's Avatar
Default Re: Advice on Project.
An academic project is not just developing another software tool. The project scenario should be applicable to broader mass. If you are a WBUT student ,this scenario will be difficult to be accepted as a project. So be careful before proceeding further because if it is rejected at an advance stage, your effort so far will go in vain. you can PM me for further suggessions.
Desktop: P-IV 2.4GHz, 512MB DDR, 865GBF Mother Board,
G-Force 5200FX, 17" Samsung flat, WinXp with SP2,
Kaspersky Internet Security 2009.
Laptop:LENOVO 3000 C100 D7 lappy with 2GB DDR2.
bukaida is offline
Old 14-09-2006, 10:59 AM   #3 (permalink)
Thor's Avatar
Oh! I am in NIT Durgapur. Cud u give examples ?
Thor is offline
Old 18-09-2006, 11:54 AM   #4 (permalink)
Thor's Avatar
*bump* ??
Thor is offline
Old 21-09-2006, 04:35 PM   #5 (permalink)
altimate's Avatar
NIT durgapur is a renowed inst.
how can u think of setting up a project work like this in ur college project submission??
choose ur project which is not widely available on the internet as a download
It should meet specific requirements.
And damn these win Xp tweaking S/Ws are in thousands......
altimate is offline
Old 22-09-2006, 12:51 PM   #6 (permalink)
bukaida's Avatar
Thumbs up Re: Advice on Project.
Here is a guideline for the project--
1. Acknowledgement
2.project completion certificate from HOD & Guide.
3. Content
4.Abstract
5. Preliminary investigation
6. Feasibility analysis(Technical, Functional & operational).
7.Literature Survey
8.Hardware & Software requirements.
9.SRS
10.System Design(Top Level Flow chart & DFDs)
11. Database Design
12. Detailed design( 2nd level DFD and Flow Charts)
13.Algorithms/Coding.
14. Output Screens
15.Testing and Validation
16.Implementation
17. conclusion
18.Bibliography
19.Future Enhancement
20.User manual.
So it is not just sit and start coding.If you have any further questions about any of the head mentioned above, post your query here.
please see these links
A brief description of project scenarios
http://www.ibm.com/university
http://www-128.ibm.com/developerwork...rary/5170.html
http://www-128.ibm.com/developerwork...rary/4166.html
http://www-128.ibm.com/developerwork...esign_Synopsis
http://www-128.ibm.com/developerwork...rary/4871.html
http://www-128.ibm.com/developerwork...o-design6.html
http://www-128.ibm.com/developerwork...it-kelby_user/
Although I have informed them to you through PM but thinking that they can also help others, I am posting it to the forum.
bukaida is offline
Old 24-09-2006, 11:09 PM   #7 (permalink)
Thor's Avatar
Whoa! Thanks!
Cud u guyz elaborate over this Internship scenarios ? Like from the links abv I c that IBM Usa Takes interns , but Does IBM @ India allows Interns ?
Which other company Allows internship ? and how to go abt approaching them ?
Thor is offline
Old 27-09-2006, 12:59 PM   #8 (permalink)
Thor's Avatar
*bump again*
Thor is offline
- by Krow
