Old 12-09-2006, 05:15 PM   #1 (permalink)
Default about registry editing
sir\madam,
i made some changes in registry settings of windows xp and saved it as a .reg file somewhere in harddisk.but when i reinstalled xp, and double clicked .reg file; to my surprise not all the contents were exported however a dialog box appeared showing that all the contents were exported?????
kindly suggest me some trick so that i shall not have to manually tweak my reg. settings again & again.
mattoo is offline
Old 12-09-2006, 06:02 PM   #2 (permalink)
hansraj's Avatar
Default Re: about registry editing
matoo
........... rule of the forum... all are friends here ... no sir no madam... ok
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
hansraj is offline
Old 12-09-2006, 06:48 PM   #3 (permalink)
Beware of the innocent
ilugd's Avatar
You are trying to merge while logged in an admin account I hope?
Life is too short. Have fun.
ilugd is offline
Old 12-09-2006, 06:51 PM   #4 (permalink)
registery is very complicated thing...
so it is more safe if u apply it manually all time..
bcoz some times there are prob in backing up and restoring registery...
dharmeshhtailor is offline
Old 12-09-2006, 07:07 PM   #5 (permalink)
Google Bot
Pathik's Avatar
btw ur reg file shd merge witout ny probs...btw let our windows VI
sTAcome..... he s the registry expert....
Pathik is offline
Old 12-09-2006, 07:41 PM   #6 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Where is VG.He shud probablyy get a brdband soon
rakeshishere is offline
Old 12-09-2006, 10:25 PM   #7 (permalink)
Console Junkie
aditya.shevade's Avatar
What do you mean by " all contents were not insearted"? Which type of contents are they? (Types of keys?)
Where is VG by the way?
--- Console Junkie
aditya.shevade is offline
Old 12-09-2006, 11:31 PM   #8 (permalink)
SE><IE
Posts: n/a
@matto: well, just importing the registry after reinstalling the OS and hoping to get all the programs and settings (preferences) back will not work. There will always be some settings that need to be configured manually.
This is because lets say you tweaked something in HKEY_CURENT_USER now you reinstall the OS and try to merge the tweaks and hope to get it correct, but the problem lies how windows sees the users. It creates a SID (secure IDentifier) which uniquely identifies the users. one in a millionth time will you find the same SID after reinstallation...and yes you will never find a same SID if you simply create and delete accounts even if all the details are exactly same.
since the SID is different so the tweak may not work.
A better option will be to take back-up of system-state
As far as the saving the registry tweaks goes, just right click on the desired key and select export.
Old 12-09-2006, 11:33 PM   #9 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Here I'm
@mattoo
It'll be easy to us if u post the contents of the .REG file.
And also tell me how u took a backup of the Registry file before installing fresh windows!
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 13-09-2006, 01:01 AM   #10 (permalink)
__Virus__'s Avatar
lol manual editing is not risky???
Some million years ago, the gods put down there feet, So firmly in to the ground that no man of sword nor pen, could ever chains the rules upon which The very fundament of metal was made.
__Virus__ is offline
Old 13-09-2006, 01:13 AM   #11 (permalink)
ranjikvp's Avatar
after a fresh reinstalation of the operating system you need to import the old .reg file that you had saved on the hdd and only then it will get effected, correct me if I am wrong guys, i guess just double clicking will not updated entire registry
ranjikvp is offline
Old 13-09-2006, 01:53 AM   #12 (permalink)
SE><IE
Posts: n/a
@ranjikvp: buddy, importing and double-clicking are one and the same thing
Old 14-09-2006, 03:52 PM   #13 (permalink)
Thumbs up Re: about registry editing
thank you i kill. your help came handy. please tell me more on system-state
__________
thanks for help...please tell me more about system state
mattoo is offline
Old 14-09-2006, 08:28 PM   #14 (permalink)
SE><IE
Posts: n/a
my pleasure buddy
basically system state is used to take back-up of the current state of windows, including userprofiles etc. Here's more info
Old 27-09-2006, 02:35 PM   #15 (permalink)
thanx please tell me abt norton ghost & how to use it
mattoo is offline
Old 27-09-2006, 06:53 PM   #16 (permalink)
SE><IE
Posts: n/a
yeah! I've heard of Norton Ghost but never gave it a try.
Just get a copy from somewhere, I hope it would be pretty easy to use as other symantec products are.
Anyways, norton ghost makes an image of your OS which can be used in case you need to "reinstall". Since all that it required is copying the files back to the HDD, it usually gets done in 5-10 Mins.
If you think a bit then you'll find out that OS "must" work if you copy the files to a safe location and back again. But then, it never works that way. some permission issues come into play(even with FAT32)
Norton Ghost does a low-level copy thus eliminating the permission issues.
- by Krow
