Re: data dvd not reading
A similar thread started by me is already running. I faced similar problem in the case of multi-session DVD. After the first write(obviously without finalisation) the data can not be read by my LG DVD ROM(got hanged), but can be read by BenQ and HP DVD-Writer. After finalisation, only the first session can be read by LG DVD ROM but the writers can read all the sessions. The DVD ROM is almost 4 years old and probably it doesn't support multi-session.
If after insertion of disc your DVD Writer does not got hanged then you can try with Isobuster. Or you may try some other ROM/Writers. Good Luck!
P4 3.0GHz Dual-core.
Intel 945GNT MoBo.
1GB RAM.
Seagate 160GB SATA HDD.
HP 16X Dual Layer DVD Writer.
Coloursit 450Watt SMPS with NAVTECH cabinet.
Samsung SyncMaster 740N TFT LCD 17" monitor.
