Old 11-09-2006, 06:42 PM   #1 (permalink)
Exclamation I have a doubt
i want to install a multible o/s in one partition is it possible
forexaple :windows xp., and 200pro in c partition..
and if it's possible what will be the maximum number of o/s can be installed in a single partition???
thanQ........
fibermanco is offline
Old 11-09-2006, 06:51 PM   #2 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Default Re: I have a doubt
Its not possible and forget how many can be installed in a single partition
rakeshishere is offline
Old 11-09-2006, 06:58 PM   #3 (permalink)
Stalker's Avatar
i am with rakeshishere..................u can only install 1 os on 1 partition
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 11-09-2006, 09:30 PM   #4 (permalink)
why can't you create more than one partition
akshayt is offline
Old 11-09-2006, 09:42 PM   #5 (permalink)
SE><IE
Posts: n/a
It IS possible to install multilpe OSes on one partition. But don't try installing windows and linux/solaris on the same partition.
The no. of OSes that can be installed is dependent on the Space available on that partition. The only reason why installing multiple OSes on same partition is not recommended is because windows shares some common files which 'may' cause some problems.
Just select "leave the partition as it is" (similar) when installing windows
Old 11-09-2006, 10:45 PM   #6 (permalink)
mekalodu
iinfi's Avatar
u can install multiple OSes in one partition. i v tried it with only windows.
win2k adv server, winxp and win 2003 in the same C drive
i didnt run it for a long time.
i believe it will cause problems and wont be stable in the long run.
i dont know abt loading win n linux in the same partition
mekalodu
iinfi is online now
Old 11-09-2006, 11:21 PM   #7 (permalink)
dOm1naTOr's Avatar
Ya u can choose the installation dir while installing an MS OS. But later it will cause problems as the Program Files folder is common to both nd also cause trouble in registry while installing same app in both OS.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 12-09-2006, 12:42 AM   #8 (permalink)
Super Hero - Super Powers
n2casey's Avatar
It seems that u don't want to consume space or u have lack of space. Then also u shud install ur OS on difeerent partitions but u can save space by installing all ur drivers, essenstial softwares only at one place. i.e. install any s/w for one OS & then when istalling for other OS, use the same directory/path (as for first OS).
n2casey is offline
Old 17-09-2006, 12:30 AM   #9 (permalink)
alot of thanx for every member and i guess it wont work any more
once again thank u for clearing my doubt ...
- by Krow
